Mon Sep 10, 2012 | Post #1 | S L Gupta (Civil Engg)
From the contents given by you, it is clear that the contract is for shuttering of the roof with 4.5'' thick cement concrete on it. Now as stated by you that contractor place 6'' cement concrete in centre. So he he place some concrete extra from the contract as per requirement of design or as per site condition So labor for placing the extra cement concrete is payable to the contract. | |
Mon Sep 10, 2012 | Post #2 | kamathak2002
Join date: Sep 2012 | Post subject: Labour Cost for Roof RCC work
Dear Gupta sir,
Thank you for your reply.
Is there any standard estimating procedure to pay extra
labour cost for pouring in additional concrete.
Best Regards
Ashok Kamath | |
Mon Sep 10, 2012 | Post #3 | S L Gupta (Civil Engg)
There is no any standard because this is between you and contractor. But as per contents send by you your contractor has to do shuttering for 1585.30 sqfeet weather he lays 4.5'' or 6'' concrete. So he is not elegible for extra on account of shuttering, however he place some cement concrete mix extra approximately 70 cft for which he is entiteled for taking extra labour for laying concrete at 2nd floor roof which is approximately from Rs 1000-00 to Rs 1500-00.for which he satisfy. | |
Mon Sep 10, 2012 | Post #4 | kamathak2002
Dear Gupta sir,
Thank you again for your kind reply. I appreciate your lone
effort in replying since there were 81 viewers. Good luck to you sir
Best Regards
AshokKamath
Fri Sep 14, 2012 | Post #5 | Khalid Aleem
Join date: Sep 2012 | Post subject: Cost for construction
Dear Gubta,
I appreciate if you please let me know the construction cost of house per sq.ft. I am from Pakistan the prices of material is higher than india being the Pak rupee is week than indian rupee however if you let me know the formula of the construction material viz Sand, Cement, Iron Bar, Bajri so that I may calculate on the basis of your formula. The bricks price in Pakistan is Rs.4500/-(Pak Rupee) per 1000 bricks and cement bag of 20 kg is Rs.375 per bag and Iron bar is Rs.72000 per ton and Sand bowzer is Rs.12000 so If I make a house having 2000 sq.ft covered area what would be the cost of the house excluding paint and other work. The labour rate here in Pakistan for Mistri is Rs.600/-per day and labour Rs.400/-per day. Please advise me of the formula that I have requested for my further calculation.
Thanks and regards
Khalid Aleem
Rawalpindi (Pakistan)
Fri Sep 14, 2012 | Post #6 | bubled
Hi KhalidHave you used the Estimator ( blue bar on the top) .it is a really handy tool and has all the formulas for different materials and mixes ,also it lets you enter the price at your location ,of different items. Hope it helps! | |
Thu Sep 20, 2012 | Post #7 | Engr.Md.Faruq
Dear Gupta sir, Thanks to you for your glorious help for us. How can I estimate for total costing of R,C,C slab with centering,labor,steel,materials every things.calculation to per 100 sft.
Thanks and Regards
Md.Faruq.
Sat Sep 22, 2012 | Post #8 | Engr.Md.Faruq
Thank you for your kind reply . How can I estimate for total costing of R,C,C slab with centering,labor,steel,materials every things.calculation to per 100 sft.head labor per day 500 Tk and helper per day 350 Tk.
Thanks and Regards
Md.Faruq.(Bangladesh)
Tue Sep 25, 2012 | Post #9 | vinod
Join date: Aug 2012 | Post subject: constaruction material used in rcc roof
pls help me to calculate the material in rcc roof , my roof size is 43ft * 51 ft =2193 sq ft with four beam
cement = ?
dust =?
iron =?
iron 16mm=?
12mm=?
10mm=?
vinod kumar dahiya
Sun Jan 27, 2013 | Post #10 | Sharma
Can you please help me for getting details of rebars & thickness of raft with footing & also deatails of rebar & thickness of slabs for my house which I need to builts in Groung + 3 floor each floor Height - 10 ft, On Beam & 16 colums Size 8" x 15" & total area Each floor is (40 x 36 Ft) = 1440. | |
Wed Jan 30, 2013 | Post #11 | S L Gupta (Civil Engg)
You are constructing 4 story building, so it is advisable to take structural detail design from any structural engineer which will be safe and economical. | |
Thu Aug 21, 2014 | Post #12 | kiran
Join date: Aug 2014 | Post subject: Need a cost estimate for a house
Hi Gupta Sir,
I have a 200 sq yards land in hyderabad area, im thinking to build ground floor and first floor house in my land , so i kindly request you to let me know the complete cost which needs to be spend by me to complete that house. (Please include every thing like labor, eletrician, water etc to have it like a complete house).
Please let us know if you need any additional details from my side.
Thanks Raj | |
Thu Aug 21, 2014 | Post #13 | S L Gupta (Civil Engg)
The cost of construction depends upon the drawing of building, its elevation and specification used in the construction. The cost can be derived with the help of plan.However the cost of construction range from Rs 1000-00per sft to 1500-00 per sft.
Tue Aug 18, 2015 | Post #14 | kumarvs
sir i am construct building 20x20 room size.which type of rebar I can using for column,beam,slab,cantilever.pls mention the rebar size in mm. | |
Tue Aug 18, 2015 | Post #15 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Kumar Use 16 mm dia bars in column, 12mm bars in roof/ slab.
Tue Aug 18, 2015 | Post #16 | kumarvs
Join date: Aug 2015 | Column size,beam size,beam rebar size and ring size for 20x20 room size pls mention
Wed Aug 19, 2015 | Post #17 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Kumar The column should be 9''x9'' with 4 nos 16 mm bars and ring of 8mm 6'' c/c, beam 9''x 9'' with 6 nos 16 mm bars and ring of 8mm 6'' c,c. slab 12mm 6'' c/c on both side.
Thu Aug 20, 2015 | Post #18 | JAI PRAKASH
Sat Jul 02, 2016 | Post #19 | Asif
Join date: Jul 2016 | Post subject: Total Cost for RCC 2000 sq.ft slab
Dear S.L. Gupta ji Can you please tell the total cost for 2000 sq.ft slab (including all expenses i.e. labour/shuttering/etc) | |
Mon Jul 04, 2016 | Post #20 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Asif Cost of RCC Slab for 2000 sft, 5'' thick and cement concrete 1;2;4 proximate cost is Rs 3 lac including material, labor and MS steel bars.
