Home -> Forums -> Construction -> Start Construction -> Labour only or Labour+Material contracor
Mon Jun 24, 2013Total posts : 3
Harsh
Harsh
Topic: Labour only or Labour+Material contracor
What are main pros and cons of signing a only labour contract with contractor?
Wed Jun 26, 2013Post  #1
Post subject: Labour only or Labour+Material contracor
Dear Harsh, It depends upon which type of construction you want to do..1. to save money,time and exertion,,go for Lab+Material contractor,but beaware of cheators,Fix the specifications first and check it during construction, take  help of Architect or Engineer for technical supervision.
2. If you hire a reliable Architect or Engineer for designing and technical Supervision of construction and you have sufficient time for arranging materials,then go for Only labour contractor , who work under the guidence of Arch./Engr.Mainly it is in practice when you want a Quality construction without any compromise,it shows your involvement with the HOUSE to be constructed.
Sun Jul 07, 2013Post  #2
Harsh
Harsh
Post subject: Thanks Navneet sir for answering..pls clarify fu...
Thanks for your answer.
Pls clarify one more doubt.... You said that labour + material contract will be cost effective.
But dont you think that if suppose i can get the same quality building made by both routes, ie via a labour only contract and also via a labour plus material contract, then between these two types of contract, the labour only contract will be cheaper as contractor will not take margin on materials.
You can assume i have enought time to arrange for material and periodic technical inspection by engineer/architect.
Mon Jul 08, 2013Post  #3
Dear Harsh
           If you have time and planning than the work done through  labor rate contact will be economical and the material used is of best quality and the specification adopted is according to you and quality of work is better.Beside margin  the contractor tries to use inferior material and in habit of saving steel and cement etc.
1812
I want to construt 1200X900x50 mm chamber cover.what will be cost (material and
Last answer on 3/2/2015 11:59:21 AM. by S L Gupta (Civil Engg). Forum started by sachin kale
1990
What is the cost difference between material labour contract and only a labour c
Last answer on 6/26/2013 4:09:27 PM. by Navneet Jharia. Forum started by nithun
2786
2530
1492
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
1956
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by S L Gupta (Civil Engg). Forum started by manoj
2754
Last answer on 7/12/2018 5:49:08 PM. by S L Gupta (Civil Engg). Forum started by Hameed
4807
2390
labour
Last answer on 5/14/2013 3:14:12 PM. by Kilyen Rampton. Forum started by dan
2265
2588
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
4219
labour rate
2054
structure
Last answer on 4/21/2014 3:03:37 PM. by S L Gupta (Civil Engg). Forum started by HAMEED
3560
construction current rate
1206
what is the labour out for scaffolding
Last answer on 7/4/2020 4:29:57 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
1352
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
990
Shuttering and labour cost 1600sft
Last answer on 7/3/2020 11:13:46 PM. by S L Gupta (Civil Engg). Forum started by Sri
2560
how much labour cost of new cnstruction
Last answer on 12/9/2013 1:25:21 PM. by S L Gupta (Civil Engg). Forum started by bharat patel
2406
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
2442
3265
3278
4424
3970
2187
2695
4205
5159
2370
2288
1991
2441
2110
3190
2041
12507
2157
2005
2721
