Home -> Forums -> Construction -> Start Construction -> Labour rate
Labour rate
Sat Jun 25, 2016Total posts : 1
Topic: Labour rate
Dears,
I am discussing the rates with contractors for my home construction.
Two contractors are quoting the following prices.
i. With Construction material high quality Rs.1700/ Sq ft
ii. With Construction material Normal quality Rs.1550/ Sq ft
iii. Labour rate Rs.350/ Sq Ft
I am interested for third option of Labour contract, and feel the quoted prices are bit high
Could you share your ideas whether this quoted price is reasonable or high at the location of Madurai Region, Tamilnadu.
If so could you share the tentative reasonable price.
Mon Jun 27, 2016Post  #1
Dear Prabhu
           It is better to survey your area/ city and labor rate is good option.
4233
labour rate
2798
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
4012
labor rate for RCC work
2420
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
2603
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
2336
cost of construction of house
Last answer on 1/13/2014 2:06:06 PM. by S L Gupta (Civil Engg). Forum started by j.B.Singh
3651
3475
labour charges rates
7836
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
3196
labour cost
2363
2242
what are the rates of labour contract for making bunglow of 4000 sq ft on column
Last answer on 9/11/2012 9:27:30 PM. by sureshkhot. Forum started by narsi vekeriya
3254
Which area measurement in plan is used by contractor to calculate labor contract rate?
Last answer on 5/22/2021 1:49:37 PM. by S L Gupta (Civil Engg). Forum started by vinu
3590
Per Sq:ft rate for flooring
2283
2392
BUILDING MATERIAL RATES & PETTY JOB RATES
Last answer on 5/15/2013 12:16:14 PM. by GULSHAN RAI GULATI. Forum started by GULSHAN RAI GULATI
3911
rate analysis
Last answer on 4/17/2021 1:15:59 AM. by S L Gupta (Civil Engg). Forum started by chethan
2407
IMPORTANT
Last answer on 7/4/2020 4:17:48 AM. by S L Gupta (Civil Engg). Forum started by carola braats
3312
2236
2312
2061
