Home -> Forums -> Construction -> Basement -> Labour rates of all contractors
Thu Dec 01, 2016Total posts : 1
Roogwed adep
Roogwed adep
Topic: Labour rates of all contractors
I want total labour rates of all contractors with material rate & without material rate in detail latest rate
Fri Dec 02, 2016Post  #1
      The labor rates for construction varies from place to place and work to work. However the general rates are from Rs170 to Rs 200-00 per sft. The Through rates i.e rates with material depends upon the specification used during construction.
Basement-Construction Questions (38)
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
2420
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
4233
labour rate
2603
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
2877
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
2283
3254
Which area measurement in plan is used by contractor to calculate labor contract rate?
Last answer on 5/22/2021 1:49:37 PM. by S L Gupta (Civil Engg). Forum started by vinu
3475
labour charges rates
7836
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
3196
labour cost
4012
labor rate for RCC work
2426
Labour only or Labour+Material contracor
Last answer on 7/16/2013 11:00:12 AM. by S L Gupta (Civil Engg). Forum started by Harsh
1995
contractor
Last answer on 5/6/2013 2:30:57 PM. by dan. Forum started by dan
2406
MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
Last answer on 8/22/2013 12:12:50 PM. by Ahmed. Forum started by K S SHYAM SUNDER
3925
2336
cost of construction of house
Last answer on 1/13/2014 2:06:06 PM. by S L Gupta (Civil Engg). Forum started by j.B.Singh
3651
2372
Item rate Constructions better than square feet rate
Last answer on 7/28/2015 12:43:34 PM. by Purvi Panchal. Forum started by BUILDMARK CONSTRUCTIONS
42599
Labour Cost for Roof RCC work
9061
makan map
2774
17223
1993
2157
design of column
2282
2253
Underground water tank
2658
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Through
