Layout and House Plans
Large room without pillars in middle
Mon Sep 30, 2013
Suresh S
Topic: Large room without pillars in middle
Hi All,
Appreciate the fantastic information provided by GharExpert. I wanted to know if an Room of 26Feet x 26Feet can be constructed without a pillar in the centre. There are 8 pillars at North, Northeast, Northwest, East, Southeast, South, Southwest and West respectively. Each of the Pillars are dimensioned 30cms x 45cms.
Ideally, how many beams need to be used and what are the dimensions required ?
What would be the pros and cons of planning such structure?
Thanks in advance for all the help
Mon Sep 30, 2013
Dear Suresh S
It is better if you take the proper design from any structural engineer. You can lay either 2 or 1 beam according to column/ pillar position.Send the plan showing column in wall for taking load of beam.
1920
beautiful ceiling - very good for Seminar rooms, Auditoriums as well as large op
Last answer on 12/21/2010 6:24:46 PM. Forum started by
Vanshri
2687
i have a 550x550mm pillar in the living room.how should i treat it with
Last answer on 3/15/2010 12:32:30 PM. by
Manoj
moksha
2694
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
2195
Last answer on 7/3/2020 9:52:37 PM. by
SURESH
2994
Last answer on 8/17/2015 1:16:00 PM. by
jaydeep
12461
First floor construction
Last answer on 7/4/2020 12:01:33 AM. by
chidambar
1745
Last answer on 5/31/2016 11:11:58 AM. by
arundey
10902
Last answer on 2/8/2021 2:14:37 AM. by
John
karthik
Structure strength to build additional floor(G+4)
Last answer on 12/14/2014 10:12:17 PM. Forum started by
saravanan
1762
mohd asif
759
I am looking for a good SUV for all family of middle size
Last answer on 7/9/2021 8:32:03 AM. Forum started by
Simon
3608
Last answer on 8/12/2015 11:59:23 PM. by
jahangir
2604
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by
chandrakanth
chandrakanth
4588
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by
Amit Kumar
2525
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
8256
How much weight can the pillars take?
Last answer on 1/19/2011 1:22:06 PM. by
rajkumarbn
rajkumarbn
2108
Get me a elevation design for duplex house .ground floor with two large size win
Last answer on 7/3/2015 3:27:25 AM. by
Kundan Patel
497
Hello everyone, I would like to buy a new large refrigerator. Who can recommend
Last answer on 2/20/2022 11:03:15 AM. Forum started by
Last answer on 1/19/2022 5:51:57 PM. by
Girish
2691
Raj
2188
Amutha
2184
vanramr
2791
raghu
4520
Nitien Parmar
suryarao p
1890
santosh
2284
Deepak Giri
2265
ajay sharma
2766
u v sudhakar
3464
ramana
2356
srinivas kamsali
1967
tanaya483
2241
ramanapeddu
3595
SRIKANTH.S
2324
HIRA SINGH
2792
Alexander Graf
Mohiuddin
1548
uma shankar
2114
mohammedbasha
Brick Pillar
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
Panel doors can consist of one to six wooden panels; but this may be increased.Hollow core wooden doors are usually fo..
Bathroom Mirrors
As far as bathroom mirrors are concerned it is the practical component and it can be used as décor component. From var..
Tips for Reading Room Lighting.
The study is the most important room for the intellectuals, for students as this is the room where one builds his care..
Tips for Living Room Lighting.
Establish an adequate general illumination level to reduce the accent light, brightness, contrast.
