Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Laying RCC slab
Laying RCC slab
Fri Jan 23, 2015Total posts : 5
SAROJINI
SAROJINI
Topic: Laying RCC slab
What is the idle number of days to do ceiling after the brick work is done? how many days of curing is needed for the bricks? In our case, Within 5 days walls were completed and centering was started on 6th day and ceiling laid on 9th day. Now we see cracks in bricks due to the centering done at few places. how can it be rectified? should the bricks be removed and replaced or just packing with cement is enough? Please advice. Thanks.
Fri Jan 23, 2015Post  #1
Post subject: cracks in bricks due to the centering
Hello..! Sarojini, The new brick work required curing minimum 10 to 15 days,in your case ,the centering was started on new brick walls,it may be one of its reason...Kinly take help of local Civil Engineer / Architect , who can guide you after seeing site conditions....Regards.
Fri Jan 23, 2015Post  #2
Dear Sarojini
            It is not clear that you have seen cracks before removing shuttering or after  removing the shuttering.
    In my opinion the cracks develop during laying shuttering plates, ballies and battens by rough handling. Consult your mason and do the repair.
Fri Jan 23, 2015Post  #3
SAROJINI
SAROJINI
Thanks Sir! Shutters are not yet removed..we are able to see the cracks below lintel bricks at 2-3 places..as nails were hit even before the bricks were set..architect says while plastering they can pack the cracks..is it sufficient..if not what additional steps need to be done..
Tue Feb 03, 2015Post  #4
No need to worry. It is very common thing. Cracks will be filled during plaster.
Tue Feb 03, 2015Post  #5
SAROJINI
SAROJINI
Thanks purvi!
1886
Last answer on 4/12/2015 5:58:38 PM. by D.C.tandon. Forum started by SREENIVAS K
4836
2528
RCC Slab -Curing
3087
9893
2294
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
2407
3753
2127
2125
CRACK IN CENTRE OF SLAB
1981
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
2525
7836
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
5861
11829
cost of rbc and rcc slab
3784
difference b/w colum, beam and RCC slab
Last answer on 7/25/2013 5:09:29 PM. by LAKWINDER. Forum started by paresh
3980
Roof leakage
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Guideline for laying DPC
