Home -> Forums -> Construction -> Layout and House Plans -> Layout Design with cunstruction estimation
Tue Jan 08, 2013Total posts : 1
Chinmaya Nanda Sahoo
Topic: Layout Design with cunstruction estimation
Hello,
I am looking for a plan of G + 3 floor.
My land is situated at Bhubaneswar, Odisha with a dimension of 48Feet by 38Feet. Both East and North Side road is there.
Basic Requirements
1. Plan must be as per Hindu's Vastu Shastra.
2. Ground Floor 1BHK with free Space for Parking.
3. 1st Floor 2BHK with Balcony.
4. 2nd  Floor 1BHK 2 portions with Balcony.
5. 3rd Floor 1BHK 2 portions with Balcony.
Additional
If a small lift is possible it's better.
Chinmaya
Wed Jan 09, 2013Post  #1
Post subject: Readymade house plans on Gharexpert.com
There is a section for ready made plans on GhaExpert.
We have service for the construction cost estimate which would give you the brick by brick cost calculation.
Our detailed cost estimate pricing is based on the built up area of the house and price slabs given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.25 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.75 per sq.ft.
Above 10000 sq.ft area= Rs.1.25 per sq. ft.
We will take almost 10 business days to prepare the detailed cost estimate.
For preparing the detailed cost estimate, We need the following documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Please supply floor plans.
7. Also supply Exterior elevation and structural drawings if possible.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
If you have a question, then feel free to call 08295820011, 08295820022 or send an email to Support@GharExpert.com
2440
1717
can u plz give me plan for cunstruction on my plot size 21*41 east facing 21 fee
Last answer on 2/7/2022 11:20:01 PM. by S L Gupta (Civil Engg). Forum started by sachin bidri
5425
Last answer on 7/3/2020 9:15:14 PM. by S L Gupta (Civil Engg). Forum started by kcp
2646
Suggestion for Front Elevation Design
Last answer on 2/10/2017 2:31:28 PM. by RAJEEV SHARMA. Forum started by saiyed
3945
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by Cherryni. Forum started by Ajay Kostha
2111
Dear experts,Please provide me a layout and house plan and cost estimation for t
Last answer on 1/18/2013 1:36:29 PM. by Gunjan Utraja. Forum started by mani
5187
Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Last answer on 3/25/2011 1:57:52 PM. by Nikita. Forum started by Amogh Desai
4797
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
2827
ESTIMATION
Last answer on 10/17/2012 4:20:51 PM. Forum started by AHAMED YUSUFF
2971
i need structural details and estimation for 150yd plot
Last answer on 8/17/2012 11:36:21 AM. by Gunjan Utraja. Forum started by gangula
3179
Estimation software
Last answer on 10/10/2021 12:12:30 PM. by Lola Cooper. Forum started by chethan
8160
software
2876
estimation
2421
2504
estimation
Last answer on 4/20/2021 6:23:24 AM. by assainar. Forum started by assainar
2303
how to calculate brick estimation
Last answer on 1/22/2022 7:01:42 AM. by bhuvaneshwaran bn. Forum started by mohammed nayeemuddin
2788
14506
30*50 west facing 167 sq yards house plan
Last answer on 10/25/2021 9:50:20 PM. by seema tyagi. Forum started by Pasha
5275
Looking for good designs and estimation costs for 1000 sq yards marriage hall
Last answer on 6/27/2021 2:44:52 AM. by S L Gupta (Civil Engg). Forum started by faiz
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Porch
Porch Designs
Bedroom Design
Bedroom is the only heaven where prevails recreation and relaxation after weary day. This article draws upon general f..
Kitchen Ideas
Make your kitchen both friendly and well-organized with these creative decorating ideas. Kitchen is a one of the most ..
