Home -> Forums -> Construction -> Layout and House Plans -> Layout and plans
Layout and plans
Mon Jan 07, 2013Total posts : 2
deepak
deepak
Topic: Layout and plans
I have 30x40 site. Its West facing. I want entrance from north. Road comes in West facing.
I want to construct 1BHK House with parking in Ground floor.
Ist floor with 2 BHK
2nd Floor with 1BHK 2 portions
3rd Floor with 1BHK 2 portions.
Please suggest. Layouts and plans or Estimation will do.
Wed Jan 16, 2013Post  #1
Post subject: Ready made plans available on GharExpert.com
Dear Mr. Anandh,
We have launched ready made plans on our website.
The few that matches your requirements are given below:
http://www.gharexpert.com/House-Plans/Plan--for-30-Feet-by-40-Feet-plot-(Plot-Size-133-Square-Yards)-Plan-Code-1583/
http://www.gharexpert.com/House-Plans/Plan--for-30-Feet-by-40-Feet-plot-(Plot-Size-133-Square-Yards)-Plan-Code-1585/
We have service for the construction cost estimate which would give you the brick by brick cost calculation.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
If you have a question, then feel free to call 08295820011, 08295820022 or send an email to Support@GharExpert.com
Tue Feb 05, 2013Post  #2
Anupam Anurag
Anupam Anurag
Post subject: Design & Build Company
Dear Deepak,
Kindly share your requirements on my email id anupamanurag@gmail.com to enable our architects and designers provide you the best space utilization of the property that you are looking to develop. Alternatively, you can reach me on 09632064394.
Anupam
Layout and House Plans-Construction Questions (40)
1940
1561
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
3184
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
2489
9961
5425
Last answer on 7/3/2020 9:15:14 PM. by S L Gupta (Civil Engg). Forum started by kcp
2638
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
2363
3945
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by Cherryni. Forum started by Ajay Kostha
2019
to help layout plan for 33ft. by 39 ft.
Last answer on 11/21/2013 10:05:07 AM. by S L Gupta (Civil Engg). Forum started by firoz raza
4832
Need a house layout plan for 450 sq feet land - size - 15ft X 30ft. pls help
Last answer on 5/13/2016 1:11:58 PM. by kushagra khare. Forum started by ankur gupta
2080
new construction
Last answer on 6/25/2015 10:57:48 AM. by seema tyagi. Forum started by ranise02
1701
Require Layout suggestions for a learning Inst. On 37'*49' plot
Last answer on 4/29/2016 11:06:07 AM. by S L Gupta (Civil Engg). Forum started by Sandeep
2382
house layout plan
Last answer on 7/3/2020 11:09:42 PM. by S L Gupta (Civil Engg). Forum started by Deepak
1815
house layout plan
Last answer on 11/3/2015 11:46:11 PM. by JAI PRAKASH. Forum started by Deepak
1421
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
6441
Column placement for house
1791
Last answer on 10/20/2016 1:50:26 PM. by Beenu Phogat. Forum started by Aditya
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
