Thu Apr 12, 2012 | Post #1 | S L Gupta (Civil Engg)
At the time of laying cement concrete in the roof one should see that
It should be fully vibrated.
After laying the concrete in the sunken floor, you should finish the top surface of the sunken floor concrete with floating coat i.e. give floor finish by using cement shullary.
Make RCC wall on the side of wall in the sunken foor if possible.
Make cement concrete gola in the joints of wall and sunken floor slab and finish it properly.
To finish already laid sunken floor and others, make plater on all side walls, then after drying do bitumen on the horizontal and vertical surface of sunken floor, than apply polythene sheet on surface after that lay the cinder concrete for filling the sunken floor.
See the website gharexpert construction section for more detail about laying of RCC slb in conc section | |
Mon Apr 16, 2012 | Post #2 | resident
Join date: Dec 2010 | Thank you sir for your quick response, sorry I couldnt reply as I was out of town last week.
I have few queries in your suggestion. I couldnt follow the terms like "Cement Shullary", "Concrete Gola" "Cinder Concrete"
Also I came to know about Nano Spray from a news paper magazine, can you tell us anything about it?
Thanks again for your suggestion !!! | |
Fri Sep 11, 2020 | Post #3 | leelindsey
Join date: Mar 2020 | Water leakage in sunken portion could be due to crack in pipe, improper pipe joint or something not right with commode. crack in pipes. For water leakage issues at the commode and pipe joint, it can easily be solved by sealing the joint from outer joint surface.There could be leakage due to pan joint too. | |
Questions (39) | |
2334 views | 4 answers | Last answer on 10/25/2015 8:30:24 PM. by JAI PRAKASH. Forum started by SOUNAK SAMANTA | 2149 views | 2 answers | Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara | 2115 views | 0 answers | Last answer on 7/23/2011 2:18:10 AM. Forum started by D.Ramachandran |
| 3673 views | 2 answers | Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan | 3802 views | 4 answers | Last answer on 12/31/2020 1:23:12 AM. by . Forum started by BHASKAR | 23868 views | 8 answers | Last answer on 7/4/2020 1:57:51 AM. by GUNA. Forum started by Kapil Singhal | 2931 views | 2 answers | Last answer on 10/5/2016 11:34:14 AM. by arun. Forum started by arun | 3883 views | 1 answers | Last answer on 11/14/2015 12:49:02 AM. by JAI PRAKASH. Forum started by Rajesh | 1437 views | 2 answers | Last answer on 8/8/2017 11:57:23 AM. by S L Gupta (Civil Engg). Forum started by Arun | 1544 views | 3 answers | Last answer on 1/28/2018 4:51:24 AM. by Er.S.K.Jain. Forum started by S.Nagarajan | 1186 views | 1 answers | Last answer on 9/26/2018 12:10:06 AM. by S L Gupta (Civil Engg). Forum started by ramchander | 838 views | 1 answers | Last answer on 1/4/2019 11:05:19 PM. by S L Gupta (Civil Engg). Forum started by Dhanraj | 2257 views | 1 answers | Last answer on 3/14/2010 7:25:28 AM. by Ajit Tareeka. Forum started by MARIBEL | 2799 views | 1 answers | Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya | 2895 views | 5 answers | Last answer on 6/16/2015 4:07:50 AM. by JAI PRAKASH. Forum started by manjula | 3629 views | 5 answers | Last answer on 1/5/2022 2:15:53 AM. by S L Gupta (Civil Engg). Forum started by amog | 2245 views | 1 answers | Last answer on 4/12/2015 6:07:10 PM. by JAI PRAKASH. Forum started by amog | 5358 views | 1 answers | Last answer on 1/13/2014 2:21:22 PM. by S L Gupta (Civil Engg). Forum started by Hemant Tiwari | 1640 views | 1 answers | Last answer on 8/4/2014 10:39:37 AM. by seema tyagi. Forum started by balaji | 11 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 11 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 14 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
