Mon Nov 23, 2015 | Post #1 | JAI PRAKASH
Join date: May 2014 | 1) What are possible reasons for the leakage - Lantel not done properly, but its normal. 2)How to fix this issue - it can be cured at the time of ghol of cement on the above surface and at time of installation of tiles. 3)will the fix be permanent - yes 4) will there be any damages to the steel structure due to this leakage.- No
Mon Nov 23, 2015 | Post #2 | S L Gupta (Civil Engg)
laying RCC slab/ roof , some quantity of half mixed cement concrete is
laid due to slackness of labor or mason and where proper compaction
is not doen with vibrator this type of problem arises. Mark the portion of leakage, rough it and put some thick cement water and cure it. After laying floor, the problem will be eliminate.. | |
Mon Nov 23, 2015 | Post #3 | JAI PRAKASH
Sun Nov 29, 2015 | Post #4 | Purvi Panchal
Join date: Aug 2012 | If one more floor is going to be built upon it then no big issue.
Is it the last roof slab, then apply "water proof coating" named "Damp-proof" from asian paints. then apply cement slurry, then place tiles.
Mon Jun 20, 2016 | Post #5 | lalit
roof is one of the most common problems faced by any homeowner! The most
important thing here is not just to find a solution but to find a permanent fix
to the problem. When I faced a similar problem, I used a waterproofing compound
called Roff Hyproof. It was suggested to me by a friend since it is specially
made for roof waterproofing. Not only did it stop the leakage but the fix has remained
intact over the past two monsoons. | |
Questions (39) | |
3802 views | 4 answers | Last answer on 12/31/2020 1:23:12 AM. by . Forum started by BHASKAR | 2799 views | 1 answers | Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya | 3142 views | 3 answers | Last answer on 7/4/2020 2:00:34 AM. by S L Gupta (Civil Engg). Forum started by ekonagu |
| 1875 views | 1 answers | Last answer on 8/9/2017 12:11:12 AM. by S L Gupta (Civil Engg). Forum started by Saurabh Agarwal | 1645 views | 3 answers | Last answer on 7/4/2020 12:15:12 AM. by JAI PRAKASH. Forum started by Ram | 1437 views | 2 answers | Last answer on 8/8/2017 11:57:23 AM. by S L Gupta (Civil Engg). Forum started by Arun | 1522 views | 1 answers | Last answer on 7/3/2020 11:14:37 PM. by S L Gupta (Civil Engg). Forum started by Aravind Rahul | 8419 views | 1 answers | Last answer on 7/3/2020 11:35:51 PM. by S L Gupta (Civil Engg). Forum started by Arun | 4310 views | 2 answers | Last answer on 6/3/2013 3:24:57 PM. by muthuraj. Forum started by muthuraj | 2849 views | 2 answers | Last answer on 7/23/2013 11:24:40 AM. by g madhusudan. Forum started by JANCYSABU | 2370 views | 1 answers | Last answer on 9/7/2013 7:13:22 PM. by S L Gupta (Civil Engg). Forum started by aliceria | 1817 views | 1 answers | Last answer on 10/23/2013 1:58:36 PM. by S L Gupta (Civil Engg). Forum started by lalitha | 1599 views | 1 answers | Last answer on 8/25/2014 8:21:41 PM. by JAI PRAKASH. Forum started by lalit | 2158 views | 1 answers | Last answer on 12/26/2014 1:00:45 PM. by S L Gupta (Civil Engg). Forum started by ashok | 1837 views | 2 answers | Last answer on 1/23/2022 3:40:26 AM. by TanyaHerrera. Forum started by ashok | 1791 views | 1 answers | Last answer on 12/26/2014 12:58:07 PM. by S L Gupta (Civil Engg). Forum started by ashok | 2470 views | 2 answers | Last answer on 9/15/2011 1:33:05 AM. by S L Gupta (Civil Engg). Forum started by P. Panchal | 12251 views | 2 answers | Last answer on 1/18/2013 3:22:15 PM. by gnyoganarasimhan. Forum started by selva | 3979 views | 1 answers | Last answer on 2/25/2013 11:42:01 AM. by S L Gupta (Civil Engg). Forum started by paresh | 7 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
