Lightweight Concrete Roofing
Thu Oct 18, 2012Total posts : 1
Ted Junior
Ted Junior
Topic: Lightweight Concrete Roofing
I am planning on building my 1200 sq ft double story  house. 4 inch thick Walls are gona be, poured in  1400kg/m3 density LWC, reinforced with polypropylene fibre and welded wire mesh supported with 3/4" MS rebar at four ft spacing. I want to reduce dead load of 1st floor and top roof concrete slabs by the use of fibre/MS reinforced LWC. If someone has done it before I will appreciate for a piece of advice on specs and procedure.
Fri Oct 19, 2012Post  #1
Dear Ted Junior
I have not done in field personally, but some datta about light weight concrete is as
 Lightweight concretes can either be lightweight aggregate concrete, foamed concrete or autoclaved aerated concrete (AAC). Such lightweight concrete blocks are often used in house construction.
Lightweight aggregate concrete can be produced using a variety of lightweight aggregates. Lightweight aggregates originate from either:
  • Natural materials, like volcanic pumice.
  • The thermal treatment of natural raw materials like clay, slate or shale i.e. Leca.
  • Manufacture from industrial by-products such as fly ash, i.e. Lytag.
  • Processing of industrial by-products like FBA or slag.
The required properties of the lightweight concrete will have a bearing on the best type of lightweight aggregate to use. If little structural requirement, but high thermal insulation properties, are needed then a light, weak aggregate can be used. This will result in relatively low strength concrete.
Lightweight aggregate concretes can, however, be used for structural applications, with strengths equivalent to normal weight concrete.
The benefits of using lightweight aggregate concrete include:
  • Reduction in dead loads making savings in foundations and reinforcement.
  • Improved thermal properties.
  • Improved fire resistance.
  • Savings in transporting and handling precast units on site.
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
2106
2414
roof concrete
2413
3271
Roof Concrete Strength
1372
cellular lightweight concrete
Last answer on 8/7/2015 11:24:52 AM. by S L Gupta (Civil Engg). Forum started by Karma Tenzin
2027
1066
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
3142
sloping roof
11246
CURING ON ROOF CONCRETE
Last answer on 3/19/2014 10:26:34 AM. by Ahmed. Forum started by K Umapathi
2211
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
9195
1893
1585
RCC Roof before concrete floor
Last answer on 6/4/2013 10:29:06 AM. by S L Gupta (Civil Engg). Forum started by shilpa
2063
Minor crack in the roof concrete
Last answer on 9/22/2015 12:41:33 AM. by JAI PRAKASH. Forum started by bala
1772
Extending the Roof concrete
Last answer on 11/1/2015 7:02:15 PM. by JAI PRAKASH. Forum started by Balan
Cooper
Concrete Decor
