Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Lintel Beam
Thu Nov 27, 2014Total posts : 2
Arvind Bhaskar
Arvind Bhaskar
Topic: Lintel Beam
I am constructing a house which is having RCC frame structure.
The columns are of 1 feet by 1 feet dimension.
The plinth beam is of 1 feet and 1 1/4 feet (15 inches ) dimension.
I am using concrete block in construction.
There will be a beam at roof level.
Do I need a continuous lintel beam connecting the entire frame or lintels just on doors and windows will be sufficient.
Fri Nov 28, 2014Post  #1
Dear Arvind
        It is better if you provide continuous lintel beam connecting the entire structure, which will provide extra safety in case earthquake.
Thu Dec 04, 2014Post  #2
Yes
5692
9198
10903
Last answer on 2/8/2021 2:14:37 AM. by John. Forum started by karthik
2824
1971
Last answer on 12/5/2015 11:13:14 AM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
2192
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
2631
Lintel Prepartion,
Last answer on 7/2/2020 10:03:29 PM. by S L Gupta (Civil Engg). Forum started by manick chopra
4665
Regarding Beam
3906
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
4133
2681
My House design
2871
FOR 250 SQ FT R-B-C SALB RATE
6471
3304
3838
Roof Beam
2332
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
12253
4764
Last answer on 8/27/2012 4:35:27 PM. by Amit Hasija. Forum started by prakash
1979
5812
3793
9885
2670
4628
4143
2867
5008
1865
2801
2610
2374
2464
2638
1808
3608
6254
Types of arch
Centering
Dining
Dining Room Ceiling
Through
