Fri Dec 04, 2015
Rohit Sharma
Topic: Lintel band( Above door openings)
Hello sir,
Do I need lintel band all around the building if i m using column and beam structure or lintel just above door or windows openings is sufficient?
Lintel having 2 rods and 3-4 inch thick.
Secondly, is second class brick is called "Darra"?
Thank you
Fri Dec 04, 2015
Dear Sharma
It is better to give a RCC bend at door level and keep 4 nos 12mm MS Steel bars with 6mm rings @ 6'' c/c with 6'' height or thickness.
Fri Dec 04, 2015
Rohit Sharma
Post subject: lintel
Thnk you mr. Gupta
Did you mean just above door level or all around buildiing above door level?
and my second question is above is still pending sir, your decades of experience will help us to have safe and economical house
Thank you once again
Sat Dec 05, 2015
Dear Sharma
Lay lintel all round the building. For earth quack safety there may be 3 lintel all round the building 1st at plinth level 2nd is at door level and 3rd is at roof level.
Every area has own local language use First class bricks in construction.
9549
Earthquake Design - Plinth Band and Lintel Band
Last answer on 12/31/2020 2:02:44 AM. by
Love thy community
Kitan
2302
Last answer on 10/26/2015 11:20:10 AM. by
Vinod
1702
1171
Last answer on 5/23/2018 11:39:20 PM. by
Surinder Singh
1639
Last answer on 10/3/2016 1:51:50 PM. by
Aarti
1330
Need cost for the above mentioned doors
Last answer on 10/3/2016 1:49:57 PM. by
Aarti
2153
2014
WHEN I HAVE MAIN DOOR IN EAST FOR A EAST PLOT IS IT NECESSARY TO HAVE A OPENING
Last answer on 8/1/2011 11:13:07 PM. Forum started by
D.Ramachandran
2422
Last answer on 8/20/2015 2:23:19 AM. by
Gunjan
2122
Hi! I have shortlisted two flats 1. having main door in south direction, west op
Last answer on 3/21/2011 8:30:30 AM. by
Vasu
2248
can u say me the opening
Last answer on 3/27/2010 3:51:58 PM. by
Ajit Tareeka
rahul
2486
if the main entrance is south opening what is to be done
Last answer on 12/1/2021 12:04:35 PM. by
Marta
s.v.mahajan
5822
Gunja
2778
I have purchased a resale 1BHk 453 sq flat recently, it south west facing ,kitch
Last answer on 7/16/2011 7:57:18 AM. by
Nitien Parmar
kishor
3657
Arvind Bhaskar
3221
Last answer on 1/29/2022 2:42:19 AM. by
wenilak444
Pooja Room Door
Last answer on 6/25/2016 11:04:51 AM. by
Meda Kameswara Rao
6471
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
4133
Last answer on 1/6/2022 11:48:27 PM. by
5812
Rakeeb Rathor
3793
Pandu
9885
nasad
2670
Sreedhar
4628
ani
4143
Anamika
2866
lio
ringwang
R.Roy
5008
MANISH
3657
Arvind Bhaskar
premkumarlen
1865
carmenjames
r.n.misra
2801
Sharath Kurva
Sharath Kurva
2610
gk
2374
Adriano Peres
vamsi
2463
nuksung
2638
dayal
1808
TUNDE
3608
ragha
6254
suba
Types of arch
Inground Swimming Pool
Panel doors can consist of one to six wooden panels; but this may be increased.Hollow core wooden doors are usually fo..
