Home -> Forums -> Construction -> Brick work -> Lintel concreting
Lintel concreting
Thu May 05, 2011Total posts : 2
srinivasa
srinivasa
Topic: Lintel concreting
While doing the lintel concreting, within hours, there was heavy rain and wiped out top portion of the concrete.  When I asked the contractor to remove everything and redo the concreting, he said it won't be a problem and said that he will put some cement on the top and it will settle down.  But my concern is , since the rain was very heavy, it could have got deep and removed cement from the concrete and may cause seepage in the future.
My question is, should I go with the contractor explanation and remedy he has provided or is there anything else need to be done as a precaution so that seepage do not occur in the future?
Can you pl. help me?
Thanks,
Srinivas.
Sat May 07, 2011Post  #1
P. Panchal
P. Panchal
Post subject: concreting
Please upload photoes. let me see the problem
Mon May 09, 2011Post  #2
Dear Srinivasa
           As stated by you that rain falls on the newly cement concreting after one hour and wiped the cement contents of the top layer. It is the right procedure that place cement shullary on the top and mixed it on the top layer than finish the surface again. For the leakage/ seepage you should lay the bitumen layer i.e. hot bitumen painting and simultaneously lay polithene sheet on it after that lay  15 to20mm thick mud plaster than lay the earth for getting proper slope and lay brick tiles and after grouting with cement coarse sand 1;3 do cement pointing. care shuld be taken that the slope should be proper. For more detail please see the sub section of dampness in construction on gharexpert.com where you will find lot about dampness treatment.
6482
9222
2313
2156
3667
1866
1776
1467
5702
2687
My House design
2874
FOR 250 SQ FT R-B-C SALB RATE
4149
1982
Last answer on 12/5/2015 11:13:14 AM. by S L Gupta (Civil Engg). Forum started by Rohit Sharma
3477
Cost of concrete walls
3446
3290
2033
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by S L Gupta (Civil Engg). Forum started by kanwer sajjad
2256
sand alternate for concrete
3675
wals
3270
compound wall
21960
3291
Bedroom Wardrobes information
2253
2225
1504
1976
1741
2237
2534
1509
1917
Brick or ACC block
2030
1669
2156
1719
4760
Brick wall on RCC slab
3946
2626
Types of arch
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Tips for Cement Paint
