Wed Feb 15, 2017
Sreedhar
Topic: Load Bearing capacity
Hi Experts,
We have purchased a house where ground floor of 600 Sft is old around 18 years and extension to ground floor abour 700 Sft is new and their is first floor on top of this house which is also new.
For top floor AAC blocks are used. its a Pillar construction
Old pillars are of 9X9 with 12 MM four rods and the new extension is 18X9 pillar size in total 12 Pillars( 9 Old and the front 3 are new.)
My question is can i get granite flooring on my first floor, will it take the load of granite or should i go with vitrified tiles.
What is the minimum load bearing capacity of such construction. Is it 20 Kg per sqft . I am not able to decide my Engineer is saying its okay you can go but still i am getting bit nervous, so thought you are the right guys to guide.
Sreedhar
Thu Feb 16, 2017
Dear Sridhar,
In my opinion you go with floor tiles on first floor.
3424
Last answer on 1/15/2022 4:20:05 AM. by
kumar
10046
manishkumar
manishkumar
7256
Last answer on 7/4/2020 2:54:21 AM. by
gautam kumar
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
1920
please give me an idea
Last answer on 2/18/2013 1:18:56 PM. by
nithya
3941
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
7925
Last answer on 12/26/2015 7:44:40 PM. by
prasad K
2255
Last answer on 5/3/2016 12:27:42 AM. by
navneet
4925
LOAD BEARING STRUCTURE
Last answer on 7/4/2020 2:56:39 AM. by
Last answer on 1/6/2022 11:48:27 PM. by
1763
Last answer on 2/3/2022 7:29:44 AM. by
Akhil George
2210
Last answer on 9/14/2021 5:43:01 AM. by
neha
2427
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by
Rajesh
Rajesh
2131
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by
Syed Shahed
3902
construction of 1st floor
Last answer on 7/4/2020 2:30:54 AM. by
SCK
1732
8848
Last answer on 10/15/2014 1:52:38 PM. by
Ambuj
6531
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by
DK
3549
Installation of solid load bearing granite/sandstone columns.
Last answer on 4/19/2012 12:05:30 PM. by
Rajan S.Raj
Rajan S.Raj
5810
Rakeeb Rathor
3791
Pandu
9883
nasad
4626
ani
4142
Anamika
2865
lio
5213
ringwang
R.Roy
5006
MANISH
3655
Arvind Bhaskar
premkumarlen
1863
carmenjames
r.n.misra
2799
Sharath Kurva
Sharath Kurva
2609
gk
2372
Adriano Peres
vamsi
2462
nuksung
2637
dayal
1807
TUNDE
3607
ragha
6253
suba
Specification of Steel
