Load bearing
Load bearing
Tue Jan 14, 2014
Syed Shahed
Topic: Load bearing
Hi everyone,
I would like to know if constructing a house on load bearing walls is cheaper / economical than constructing the house on column structure. If yes, is there a huge difference? And does the sand requirement goes up if we in for a load bearing one? Pls advise.
Fri Jan 17, 2014
Dear Syed
Up to 3-story building load bearing wall construction in the house is some what economical. The requirement of sand is almost same in both cases.
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
7257
Last answer on 7/4/2020 2:54:21 AM. by
gautam kumar
2210
Last answer on 9/14/2021 5:43:01 AM. by
neha
4128
Last answer on 1/6/2022 11:48:27 PM. by
1764
Last answer on 2/3/2022 7:29:44 AM. by
Akhil George
2256
Last answer on 5/3/2016 12:27:42 AM. by
navneet
4925
LOAD BEARING STRUCTURE
Last answer on 7/4/2020 2:56:39 AM. by
Last answer on 12/26/2015 7:44:40 PM. by
prasad K
3424
Last answer on 1/15/2022 4:20:05 AM. by
kumar
2427
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by
Rajesh
Rajesh
6532
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by
DK
8849
Last answer on 10/15/2014 1:52:38 PM. by
Ambuj
3934
load bearing walls
Last answer on 12/7/2020 12:04:44 AM. by
mohan
mohan
2762
Last answer on 8/21/2014 2:44:43 PM. by
ADINATH
Anu Rajbanshi
3550
Installation of solid load bearing granite/sandstone columns.
Last answer on 4/19/2012 12:05:30 PM. by
Rajan S.Raj
Rajan S.Raj
2525
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
3013
Last answer on 8/29/2014 2:08:09 AM. by
ADINATH
1839
How to plan steel dimention for load bearing pillars
Last answer on 8/5/2015 4:41:11 AM. by
Joshy
2670
Sreedhar
Specification of Steel
