Home -> Forums -> Construction -> Fine Sand -> M-Sand for Plastering
Sat Oct 10, 2015Total posts : 3
Satheesh
Satheesh
Topic: M-Sand for Plastering
Construction for G+3 floors  is in progress and using the Robo sand & stone dust for brick work/mold.
Due to the high cost & non availability of river sand, planning to use, M sand for plastering.
Could you please help me to know the pros & cons of M sand in Plastering?
Also, what would be better alternative than the river sand in vitrified tiles laying work?
Thank you very much in advance!!
Mon Oct 12, 2015Post  #1
        You can use M sand for plastering. See that there should minimum silt i.e the silt should be less than 4%. If this problem of silt exist than wash the sand with water for removing the silt.
Mon Oct 12, 2015Post  #2
Satheesh
Satheesh
Thank you very much Mr.Gupta..
Wed Oct 14, 2015Post  #3
Thanks Sir Ji.
Fine Sand-Construction Questions (27)
2521
construction const
2197
Usage of M-Sand in Bangalore
2436
Gypsum Plaster Vs S/C Plaster
7214
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by jaydeep. Forum started by S. Krishnamoorthy
3712
2011
coarse aggregate
1624
1762
1456
1870
suggest for exterior
2110
Gypsum plastering
Last answer on 7/3/2020 11:51:16 PM. by Purvi Panchal. Forum started by sanu kumar
2217
Last answer on 5/24/2021 4:53:02 AM. by Abhishek Garg (Builder & Engineer). Forum started by vamsi
2924
2157
2327
Sand units
1706
Sand units
1525
Sand units
2101
river sand
2192
2327
Sand units
1706
Sand units
1525
Sand units
16072
robo sand vs natural sand
2035
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
2809
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3525
alternative for river sand
Last answer on 6/11/2011 9:17:04 AM. by S L Gupta (Civil Engg). Forum started by sudakar
Gypsum
Checklist for Cement Plaster
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
