Home -> Forums -> Interior -> Interior Lifestyle -> MADAM,I AM HAVING 200SQYD OF OPEN PLOT WHERE I WANT TO START A CONSTRUCTION FOR
Sat Jun 23, 2012Total posts : 1
mrs sudha
mrs sudha
Topic: MADAM,I AM HAVING 200SQYD OF OPEN PLOT WHERE I WANT TO START A CONSTRUCTION FOR
MADAM,I AM HAVING 200SQYD OF OPEN PLOT WHERE I WANT TO START A CONSTRUCTION FOR A DUPLEX HOUSE IE A HALL WITH NO DINNING SEPERATION BUT A SMALL FLOOR ELEVATION FOR THE DINNING AREA AND A KITCHEN 3 PERSONS TO BE FITTED AND A SMALL PUJA ROOM WITH A GLASS DOOR AND A ATTACHED BATHROOM IN GROUND LEVEL AREA AND A STAIR CASE FROM INSIDE THE LIVING ROOM AND TWO BED ROOMS WITH ATTACHED BATHROOMS AND A LONG AND OF MEDIUM ROOM FOR A DRESSING ROOM IN BETWEEN THE BEDROOMS WILL IT BE POSSIBLE AND MY PLAN IS ONLY THE LIVING AREA NEED A STYLISH CEILING DESIGN HAVE SEEN UR PIC WAS VERY NICE AND WITH SAME LIGHTINGS ON IT AND FLOORING FOR THIS PARTICULAR LIVING ROOM ANY BLACK MARBLE AND THE ABOVE SAID STYLISH CEILING IN BLACK AND KITCHEN DOORS NEED A GLASS DOORS LIKE FRENCH DOOR OPENINGS MAM I NEED ONE BATHROOM WITH GLASS DOOR AND LITTLE COMFORTABLE PLACE THAN THE OTHER BATHROOM FOR A MASTER BEDROOM MAM MY BUDGET IS WITHIN 10 LAKHS CAN I FULLFILL THESE NEEDS I NEED A ESTIMATION AND MAMENTRANCE FROM THE MAIN YARD NEED A CARPARKING PLACE AND IF POSSIBLE CAN I GO FOR A SMALL LAWN SORRY FOR THE TROUBLE, THANKING YOU
Sat Jun 23, 2012Post  #1
Swati Satija
Swati Satija
Post subject: Architectural House Plan for 2oo sq yard
Ms. Sudha
GharExpert launched a very cost effective architectural plan service that is available at the link below:
  • You select a plan whose layout you like. Note down the plan code and purchase the plan.
  • Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
  • We will assign a representative for your project and he/she will coordinate all your requirements.
  • After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
  • If you also purchase guidance from Vastu expert then an independent vastu expert be assigned toyour project and he/she will review your plan and suggest changes.
  • Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
  • If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
  • If you choose a 3-D option too, then the process works as below.
    • After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
    • Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
  • If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plans. Your contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
Please visit the links given below for reference.
http://www.gharexpert.com/House-Plans/Plan--for-30-Feet-by-60-Feet-plot-%28Plot-Size-200-Square-Yards%29-Plan-Code-1429/
http://www.gharexpert.com/House-Plans/Plan--for-30-Feet-by-60-Feet-plot-%28Plot-Size-200-Square-Yards%29-Plan-Code-1310/
Swati
Interior Lifestyle-Interior Questions (38)
2742
Last answer on 8/11/2017 2:15:35 AM. by HOME. Forum started by parveen sharma
3031
Last answer on 2/21/2022 6:45:23 AM. by S L Gupta (Civil Engg). Forum started by parkash
2474
4449
if y have t junction plot what is the solution i am having south facing plot wit
Last answer on 8/21/2014 2:37:19 PM. by Dilavarsinh Vaghela. Forum started by sudhir samdani
1892
Last answer on 3/30/2016 12:19:00 PM. by shaikomer. Forum started by shaikomer
2771
Is the construction on the plot having east facing , and wider on front side and
Last answer on 9/6/2010 9:29:25 AM. by Gunjan Utraja. Forum started by Praveen
3216
for a flat
Last answer on 10/13/2010 5:18:56 PM. by lokareddy. Forum started by shrawan
2263
PLAN FOR EAST NORTH ROAD 32 FT WIDE AND 45 FT DEPTH
Last answer on 6/3/2015 9:59:12 AM. by seema tyagi. Forum started by jagdish chand
2233
Last answer on 3/5/2016 9:22:48 PM. by JAI PRAKASH. Forum started by saideep
3090
3474
2305
1334
2836
Last answer on 9/15/2015 12:39:30 PM. by S L Gupta (Civil Engg). Forum started by ravi
4074
4256
3157
I m starting my new business of construction , kindly help me with some details
Last answer on 7/24/2021 4:15:31 AM. by Rinder76. Forum started by Tarun
2675
plot having west side &south side road
Last answer on 8/21/2014 2:42:37 PM. by Dilavarsinh Vaghela. Forum started by rahul kulkarni
8126
Modern Kitchen
Last answer on 2/19/2022 3:13:17 AM. by Gohkadd. Forum started by ankita
2560
where you provide your service.
Last answer on 12/23/2021 1:47:07 AM. by Amit Hasija. Forum started by mmehtab
2387
beautiful collection. i like the desigin
Last answer on 5/24/2021 2:50:46 AM. by fenix33. Forum started by G.Kasinathan
1790
i definetally love this exclusive designs,my quetion is do you offer training to
Last answer on 4/14/2021 1:57:37 AM. by S L Gupta (Civil Engg). Forum started by coaste
2826
Do you suggest storage below coaches in living room?
Last answer on 12/31/2020 2:46:30 AM. by Gunjan Utraja. Forum started by pradnya
2366
how this wall is detailed in differnt levels, with wht material???????? If i go
Last answer on 12/31/2020 2:39:31 AM. by Shally. Forum started by deepti mangla
2820
i am liking the design a lot Tell me How this glass in the ceiling is detailed
Last answer on 12/31/2020 2:39:30 AM. by Shally. Forum started by deepti mangla
2572
This looks too good, Can i have more details.... I am impressed.
Last answer on 12/31/2020 2:33:38 AM. by Gunjan Utraja. Forum started by raghuns1974
2956
Home Decorating Tips
Last answer on 8/5/2020 8:19:53 AM. by heltonexpert. Forum started by chenar
2069
more informations about a living room but with some storge
Last answer on 8/5/2020 12:03:03 AM. by axelbach. Forum started by josephine
1973
i want same tipe work in my home
Last answer on 8/5/2020 12:02:15 AM. by axelbach. Forum started by S.N. Sharma
3002
Design Home Office
Last answer on 7/4/2020 12:16:39 AM. by syammadala. Forum started by mukesh2766
4784
I am n interior designing student so i want more information about carpet making
Last answer on 7/3/2020 11:13:00 PM. by Swati Sharma. Forum started by Swati.Gosalia
3009
2851
Last answer on 9/19/2012 6:08:49 PM. by tjackson. Forum started by Sujatha Kumar
2876
what material use in wall unit
Last answer on 5/31/2012 4:16:57 PM. by Gunjan Utraja. Forum started by sonali
2346
Last answer on 5/31/2012 4:15:46 PM. Forum started by sonali
2475
Glass Partitions
Last answer on 12/2/2011 2:23:04 AM. by RAFAHMED. Forum started by Donna Burke
2096
The picture looks like a bath tub above ground or poooool,misunderstanding......
Last answer on 6/18/2011 3:06:22 PM. by Gunjan Utraja. Forum started by Jitendra Sharma
Porch
Porch Designs
Design
Design your Office
