Steel
Fri Jan 08, 2016
DURJOU KUMAR MONDAL
Topic: HOW MANY COLUMN & BEAM REQUIRED
DEAR Sir,
My plan is 55 feet x 35 feet for 1st to 3rd floor will be same,where ground floor will be free from any room.My requirement is that how many column will be required for that plan & what type of steel required for column & beam.
Pl see the attachment to see my plan where mentioned the side.
Please advise me & don't wrote me that "please you contact our ghar expert"
Durjoy Kumar Mondal
PROJECT OF 1ST TO 3RD FLOOR.xls on Fri Jan 08, 2016,&n
Fri Jan 08, 2016
DURJOU KUMAR MONDAL
Post subject: Gupta Sirjee
Dear Gupta Sirjee,
Please don't skid my question to an another way & am specially want to know the answer from you as per most experience. My no is 9933021800
Durjoy Kumar
Sun Jan 10, 2016
You need around 26-28 columns. Please check the attached file. Please contact any structure engineer for the correct quantity.
PROJECT OF 1ST TO 3RD FLOOR.xls Sun Jan 10, 2016,&n
Mon Jan 11, 2016
DURJOU KUMAR MONDAL
Post subject: Joy prakashjee
Dear am really so glad for u that u revert my question.
Mon Jan 11, 2016
Post #4
Dear Mondal
The proper way of find out MS Steel bars number and diameter is to derive from structural drawing based on calculation of span of column load coming on beam and column, earth quack safety factor. So it is advised to take proper design from any structural engineer which will better in long run saves cost of MS steel and take factor safety.
Mon Jan 11, 2016
Post #5
DURJOU KUMAR MONDAL
Post subject: Special Thanks to Gupta Sir
Dear Gupta Sirjee,
Special thanks to u for advised me which was i admired.
5218
ringwang
R.Roy
1316
Last answer on 8/12/2020 3:57:29 AM. by
baba morris
Er.S.K.Jain
2723
Last answer on 5/17/2014 12:39:31 PM. by
gaurav
Yousuf khan
2707
Last answer on 7/3/2020 9:48:52 PM. by
Mohiuddin
2264
STEEL BEAM & COLUMN
Last answer on 1/12/2016 12:30:46 AM. by
DURJOU KUMAR MONDAL
1943
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
3842
Roof Beam
R.Roy
1370
Last answer on 7/28/2020 12:37:49 AM. by
vishal singh
1900
COLUMN & BEAM WIDTH & HEIGHT REQUIRED
Last answer on 1/23/2016 8:27:23 PM. by
DURJOU KUMAR MONDAL
Last answer on 1/30/2016 2:05:49 AM. Forum started by
rehan
Last answer on 1/30/2016 2:12:53 AM. Forum started by
rehan
10056
manishkumar
manishkumar
3304
Last answer on 7/3/2020 10:11:02 PM. by
manjula
1610
Respected Sir,We are constructing a individual house at an area of approx 450sq
Last answer on 12/2/2016 11:53:14 AM. by
ranjeet
1537
Last answer on 12/2/2016 11:43:21 AM. by
ranjeet
2159
New 4 storey building design
Last answer on 3/5/2016 10:15:22 PM. by
Raidang
2039
Last answer on 6/16/2015 4:44:30 AM. by
Lawrence
2712
Last answer on 3/12/2021 10:44:44 PM. by
Lawrence
2306
Last answer on 2/22/2022 2:56:11 AM. by
Lawrence
2691
steel requirment
Last answer on 2/1/2022 2:47:12 AM. by
skziro
vijaygutti
15614
Last answer on 7/26/2021 2:26:58 AM. by
Residential complex
Last answer on 6/30/2021 4:27:52 AM. by
lali
4372
RCC Columns
Last answer on 4/14/2021 6:24:55 PM. by
Ahmed
Ahmed
3243
Last answer on 12/31/2020 2:29:45 AM. by
Prem Bhatia
Shabbir Manzoor
7489
Bar Bending Schedule Software
Last answer on 12/13/2020 8:18:39 PM. by
kongrollo
Prasenjit Roy
2526
steel
Last answer on 7/3/2020 10:06:06 PM. by
saravana prabu
29963
Last answer on 9/26/2018 12:16:44 AM. by
Balaguru
2615
Last answer on 7/23/2018 11:36:52 PM. by
AMIT KUMAR VERMA
9369
Last answer on 5/21/2018 11:53:16 PM. by
George Kattapuram
2287
Current iron rod price
Last answer on 4/23/2018 11:26:02 PM. by
lio
2612
Last answer on 1/27/2017 1:11:45 PM. by
1890
Steel Erectors
Last answer on 8/22/2016 11:36:29 AM. by
MarianneRolfe
MarianneRolfe
Last answer on 4/18/2016 11:23:43 PM. Forum started by
Kaleemullah
Kaleemullah
3275
Last answer on 1/11/2016 12:39:36 PM. by
DURJOU KUMAR MONDAL
13797
overlap length to steel
Last answer on 6/16/2015 4:11:51 AM. by
shaik khaja nayab rasool
2164
Last answer on 12/26/2014 1:19:11 PM. by
pramod Kumar patel
2540
Last answer on 10/12/2014 9:10:09 PM. by
Rohit Patel
Dining Room Ceiling
