Home -> Forums -> Construction -> Start Construction -> MIX PROPORTION
MIX PROPORTION
Thu May 12, 2016Total posts : 1
Topic: MIX PROPORTION
On site, which ratio of cement:sand:aggregate is used for column,slab and masonary work? (i want mass ratio not volume ratio.)
Fri May 13, 2016Post  #1
uDear Mada
          The ratio for cement masonry is 1:6 for 4'.5'' thick wall it should be 1:4 it may measured by volume or do it by weight. For cement concrete ratio is 1;2;4 but due to earth quack and increasing natural calamities now it is preferred to use 1;1.5;3 ratio for cement concrete in column, beam and slab.You  may use by volume or by weight.
2679
4365
WHAT IS THE RATIO
1766
1460
3277
3770
concrete mix design software
3791
3389
1:2:4 mix or 1:3:3 mix
Last answer on 3/18/2014 1:08:38 PM. by S L Gupta (Civil Engg). Forum started by navneet
2002
Dear Sir iam sr.civil engineer with adequate experience.so please tell me the pr
Last answer on 1/16/2021 1:07:32 AM. Forum started by SANJAY DUSANE
2135
READY MIX PLASTER
1665
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
1764
1686
3350
Study Room Vastu
Last answer on 1/29/2021 7:27:25 AM. by dorishall. Forum started by Avinash Ojha
2548
Water for Construction
6462
4241
mix design of rcc slab
Last answer on 7/31/2012 11:18:03 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
3200
Ready Mix Concrete
4372
Ready Mix Concrete
3310
Concrete Mix Ratio
Ready
Ready Mix Concrete
Right size cupola
Cupola Proportions
Tips for cupola proportions
CONCRETE
Tips for Oil Bound Distemper
