Home -> Forums -> Construction -> Steel -> WHAT MM STEEL REQUIRED FOR 48 FEET HIGHX12''X18'' COLUMN
Fri Jan 08, 2016Total posts : 2
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
Topic: WHAT MM STEEL REQUIRED FOR 48 FEET HIGHX12''X18'' COLUMN
Please advised me that what type of steel rod required for 48 feet high x 12'' x 18''column & 9'' x 12'' beam,where building will be g+3rd each roof will be  1900sft.
Please advised me.
Sun Jan 10, 2016Post  #1
Use 24 mm TMT for 12x18 column and 16 mm for 9x12.
Mon Jan 11, 2016Post  #2
Dear Mondal
             The proper way of find out MS Steel bars number and  diameter is to derive from structural drawing based on calculation of span of column load coming on beam and column, earth quack safety factor. So it is advised to take proper design from any structural engineer which will better in long run saves cost  of MS steel and take factor safety.
2259
STEEL BEAM & COLUMN
Last answer on 1/12/2016 12:30:46 AM. by JAI PRAKASH. Forum started by DURJOU KUMAR MONDAL
2907
map & design
Last answer on 11/4/2020 4:07:42 AM. by leelindsey. Forum started by Akash
1940
1531
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
3030
1893
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by S L Gupta (Civil Engg). Forum started by DURJOU KUMAR MONDAL
2994
2910
4939
COLUMN AND STEEL DESIGN
4939
2421
start construction Steel use
1604
Last answer on 12/2/2016 11:53:14 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
2382
15582
1902
roofing
Last answer on 10/14/2015 3:25:36 AM. by JAI PRAKASH. Forum started by sumit
1878
PERFECT STEEL HEIGHT,WIDTH & NO OF QUANTITY
Last answer on 1/25/2016 2:31:29 PM. by DURJOU KUMAR MONDAL. Forum started by DURJOU KUMAR MONDAL
2866
Steel calculation
721
2684
steel requirment
15582
1992
Residential complex
4369
RCC Columns
3238
7479
Bar Bending Schedule Software
2521
steel
29942
2613
9362
2260
Current iron rod price
2606
1885
Steel Erectors
2382
13772
overlap length to steel
2160
2539
Type
HSD
Precautions
