Wed Apr 30, 2014Total posts : 1
mangesh yenwaskar
mangesh yenwaskar
Topic: WHICH MM OF STEEL USED IN SLAB AREA
Thu May 01, 2014Post  #1
Ahmed
Ahmed
Hi
Use 10mm rods, which is the standard for residental buildings
Steel calculation
1657
1903
roofing
Last answer on 10/14/2015 3:25:36 AM. by JAI PRAKASH. Forum started by sumit
2503
What will be coast of slab 5" for area of of 450Sq feet. I want material cost l
Last answer on 10/12/2014 9:25:00 PM. by SANJAY DUSANE. Forum started by milind
3033
4331
3721
32561
Cost of RCC Pillar
8652
1273
1543
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
2421
start construction Steel use
5692
3108
4836
3626
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2690
Last answer on 7/2/2021 3:17:17 PM. by B Thakar. Forum started by minhaj sk
1992
Residential complex
1831
23
27
Hard
Skylight
Types of Cement
Type
