MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
Tue Aug 13, 2013Total posts : 2
K S SHYAM SUNDER
K S SHYAM SUNDER
Topic: MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FI
MY CONTRACTOR IS CHARGING THE SAME RATE OF CONSTRUCTION FOR GROUND AS WELL AS FIRST FLOOR AND ALSO FOR COMMON PASSAGE AND CAR PARKING .IS IT FAIR ENOUGH
Fri Aug 16, 2013Post  #1
Dear KS
      The rates settlement is your own matter. But The rates may be varies from car parking, passage and ground and first floor.
Thu Aug 22, 2013Post  #2
Ahmed
Ahmed
Hi
Mine is a fresh experiance...
Price for ground and 1st floor will be same if he is doing water proofing compund with cooling tiles and will be leave 3ft pillars on the terrace for extension with cement packing.
Price for car park is same if he is covered (with roof slab) and antiskid tiles on the floor and front side main grill gate.
Again it all depends on the specifications...
also want to know the rates of double bed that carpenters charge in lucknow
Last answer on 9/3/2014 2:45:28 AM. by JAI PRAKASH. Forum started by neelam rathi
2878
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
2798
2372
Item rate Constructions better than square feet rate
Last answer on 7/28/2015 12:43:34 PM. by Purvi Panchal. Forum started by BUILDMARK CONSTRUCTIONS
4108
3993
1977
Contractor charge details
Last answer on 3/28/2014 12:09:26 PM. by S L Gupta (Civil Engg). Forum started by sandeep dutta
929
Olen täysin tyytyväinen asiakaspalveluun ja moniin peleihin, jotka löysin osoitt
Last answer on 8/27/2021 6:13:20 AM. Forum started by klichl
3475
labour charges rates
1810
Last answer on 1/27/2016 12:04:33 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2525
2512
2392
BUILDING MATERIAL RATES & PETTY JOB RATES
Last answer on 5/15/2013 12:16:14 PM. by GULSHAN RAI GULATI. Forum started by GULSHAN RAI GULATI
1784
Current construction cost for Marble and Vitrified flooring
Last answer on 12/4/2009 2:54:24 PM. by narendra barde. Forum started by rajendra
1871
5060
946 squre feeti estimate in kolkata
Last answer on 9/8/2014 9:14:34 PM. by JAI PRAKASH. Forum started by jitendra
2020
1596
IS THERE ANY DIFF. IN CONSTRUCTION CHARGES WITH MATERIAL FOR MUMTY , SEPTIC TANK
Last answer on 10/20/2016 12:44:55 PM. by S L Gupta (Civil Engg). Forum started by ANIL AGRAWAL
18
Preliminary
Through
Pool Pumps
