Main Door Size
Wed Jun 08, 2011Total posts : 3
sumit dua
sumit dua
Topic: Main Door Size
I am constructing a house which will have a main gate at the front. But for main entrancedoor to home, what should be the standard door width ?
I know it may vary. But what's the most normal/standard width ? Can I keep it at 3 feet ?
Any response will be highly appreciated.
Thanks,
Sumit
Wed Jun 08, 2011Post  #1
Dear Sumit
  The entrance door should be at least 4 feet wide and keep two equal shutters of the door. Every items used in the house or house hold will be taken via main entrance so it should have sufficient width so that there should no any difficulty for taking items inside the house.
Thu Jun 09, 2011Post  #2
P. Panchal
P. Panchal
Post subject: main door size
Hi Sumit
for entrance door openable part (shutters) should be 42 inch or 36 inch in width. Not less then 36 inch.
Fri Jun 10, 2011Post  #3
sumit dua
sumit dua
Thank you sir for the response.
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by S L Gupta (Civil Engg). Forum started by padma
5289
if anybody have good main door frame models pics?,prefer rectagle model size 210
Last answer on 8/9/2013 10:15:39 AM. by GUNA. Forum started by rense
3697
about size of chowkets
2678
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by S L Gupta (Civil Engg). Forum started by nagaraja k.n.
2317
hi i want to know in which direction should be the main door of the house?where
Last answer on 11/18/2013 1:29:34 PM. by S L Gupta (Civil Engg). Forum started by manisha
2606
Yes sir main naya ghar bana raha hoon. Aur US main doors lagwane hain jis ke li
Last answer on 5/14/2015 4:18:22 AM. by JAI PRAKASH. Forum started by Krishna kumsr
2622
Vastu of the attached flat
5822
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1639
1267
1679
How to calculate in which pads does our design of house main door comes
Last answer on 9/16/2016 7:15:35 AM. by Suprabha. Forum started by Suprabha
1316
main door north facing
Last answer on 2/10/2017 12:00:40 PM. by S L Gupta (Civil Engg). Forum started by B.V.GIRIDHAR
1252
East face house main door exact opposite neem tree there is it good or bad
Last answer on 7/3/2020 11:47:46 PM. by JAI PRAKASH. Forum started by K.Raj Kumar
3047
2746
i want information about main door of flat as per vastu
Last answer on 3/10/2011 12:07:54 PM. by Nikita. Forum started by snehal
2590
can we construct stairs in south east in front of the main door or not
Last answer on 10/27/2021 1:08:48 AM. by abid_baig@yahoo.com. Forum started by ravinder
3057
Dear Sir, Kindly send me the picture of main door for new interier desing
Last answer on 2/25/2022 3:02:58 AM. Forum started by Anup
24
28
Right size cupola
What is binding wire
