Home -> Forums -> Vastu -> Dining -> Main Entrance Door
Tue Dec 06, 2011Total posts : 3
raghuam
raghuam
Topic: Main Entrance Door
Dear sir,
I am mallik.My new house is in construction.On the Main entrance door, which diety or flowers are good to carve for Fame and Prosperity also Health of my family.Main door Facing east.please let me know.
thank you sir,
Raghu.
Wed Dec 07, 2011Post  #1
ramu771964
ramu771964
Post subject: Suggestions for Main Entrance Door - V.Ramakrish...
It is better to have Two split doors for Main Doors ,
Make Carving Ganesh Murthy if the door is Single leaf door, with outlining Flowers. Ganesh at centre.
Make Carving of Peacocks on either doors if door is of Two Leafs. with outlining Flowers. Peacocks at centre on each door.
These give you prosperity...............
V.Ramakrishna,
vanapalli77@gmail.com
Thu Dec 08, 2011Post  #2
raghuam
raghuam
Dear  Ramu sir,
My builder is not allowing to carve anything on the main door as the elevations of the building is effected.please suggest any other alternative.
thanks,
raghuam
Fri Dec 09, 2011Post  #3
Post subject: 4 Tips to Decorate Entrance Doors
Resp. Sir,
There is an article titled "4 Tips to Decorate Entrance Doors" from GharExpert.com on link given below:
http://www.gharexpert.com/articles/Doors-1758/4-Tips-to-Decorate-Entrance-Doors_0.aspx
Please see if this can help you.
Dining-Vastu Questions (27)
1267
2104
Bathroom door facing main entrance door in flat .can it be any problem?
Last answer on 7/16/2014 10:41:41 AM. by S L Gupta (Civil Engg). Forum started by ANURAG DUBEY
2289
our date of birth 17/08/1968 which we want put Main entrance Door Please tell me
Last answer on 1/5/2022 9:19:55 PM. by JAI PRAKASH. Forum started by Vasudev
2542
Door direction
Last answer on 6/28/2021 8:16:16 AM. by youtubevanced. Forum started by Rohit Patel
2287
my friends flat has east aagney main entrance door.please give the remedy for th
Last answer on 12/4/2013 2:47:20 PM. by S L Gupta (Civil Engg). Forum started by iangaswamy
3406
1734
Foyer design
Last answer on 8/6/2013 4:44:59 PM. Forum started by nithun
2622
Vastu of the attached flat
1252
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2431
No of doors in a house
Last answer on 11/18/2013 1:26:11 PM. by S L Gupta (Civil Engg). Forum started by Pramod Kumar
5462
Underground water sump
Last answer on 2/27/2015 11:50:23 AM. by revadi. Forum started by hb
3697
about size of chowkets
2484
door design
Last answer on 2/14/2014 4:17:10 PM. by Navneet Jharia. Forum started by chethan
2425
door design
Last answer on 11/24/2021 10:01:15 PM. by S L Gupta (Civil Engg). Forum started by chethan
2072
main entrance for house
Last answer on 5/19/2015 9:07:52 PM. by JAI PRAKASH. Forum started by charit
1804
main entrance for home
Last answer on 5/19/2015 9:07:45 PM. by JAI PRAKASH. Forum started by charit
2080
main entrance of a home
Last answer on 4/29/2013 12:42:45 PM. by Amit Hasija. Forum started by SOUGAT KARMAKAR
2486
if the main entrance is south opening what is to be done
Last answer on 12/1/2021 12:04:35 PM. by Marta. Forum started by s.v.mahajan
2133
poster for walls
Last answer on 1/2/2021 5:27:27 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
3051
Last answer on 12/17/2020 3:55:26 AM. by Pavan. Forum started by paresh
2196
1369
Mirror in dining roim
Last answer on 8/11/2016 12:31:30 PM. by S L Gupta (Civil Engg). Forum started by Neema
7045
Need Advice regarding Coconut Tree inside the Compound
Last answer on 1/4/2015 12:27:12 PM. by satish. Forum started by Abhi
2630
Vasthu plot size
Last answer on 2/8/2013 9:07:32 PM. by Pavan. Forum started by subbu_pl
2538
2335
can you use brilliant white gloss paint on mouldings(pop)
Last answer on 1/20/2011 8:22:05 PM. by Dinesh Manaktala. Forum started by coby
Which are various sources of entrance for termites in a building?
The timber buried in ground. The means of mud shelter tubes constructed over unprotected foundations
Panel doors can consist of one to six wooden panels; but this may be increased.Hollow core wooden doors are usually fo..
Advantages
Advantages
