Drawing Room
Thu Apr 28, 2016
Hari Krishnan
Topic: Main door entrance in apartment
Hey, I wanted to know if I should calculate directions of of main door entrance by standing outside the house and pointing towards the main door or should I be inside my house and point towards the main door? When I stand out and point towards it shows NE and when I stand inside and point it shows SW!
Fri Apr 29, 2016
Dear Harikrishnan
Why are you so confused, take magnetic compass and stand in the middle of main door and note the actual direction. If you have any more confuse than consult any vastu expert for your problem.
Tue May 03, 2016
2622
Vastu of the attached flat
Last answer on 11/14/2016 11:06:33 AM. by
Megasonali
1252
Last answer on 6/12/2018 1:25:38 AM. by
Kiran kabadi Kabadi
1267
Last answer on 7/4/2020 3:50:27 AM. by
Ravin Raman
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by
Rohit Patel
1808
Does significance of entrance door to an APARTMENT apply to everyone or is it g
Last answer on 3/2/2011 3:12:11 PM. by
Nikita
Radha
2104
Bathroom door facing main entrance door in flat .can it be any problem?
Last answer on 7/16/2014 10:41:41 AM. by
ANURAG DUBEY
2299
Entrance of apartment
Last answer on 12/3/2013 11:21:17 AM. by
swat
2287
my friends flat has east aagney main entrance door.please give the remedy for th
Last answer on 12/4/2013 2:47:20 PM. by
iangaswamy
2543
Door direction
Last answer on 6/28/2021 8:16:16 AM. by
youtubevanced
Rohit Patel
2289
our date of birth 17/08/1968 which we want put Main entrance Door Please tell me
Last answer on 1/5/2022 9:19:55 PM. by
Vasudev
3406
Dexter
plabita
3697
about size of chowkets
Last answer on 3/25/2015 9:49:46 PM. by
ARVIND GOYAL
2484
door design
Last answer on 2/14/2014 4:17:10 PM. by
door design
Last answer on 11/24/2021 10:01:15 PM. by
main entrance of a home
Last answer on 4/29/2013 12:42:45 PM. by
SOUGAT KARMAKAR
2486
if the main entrance is south opening what is to be done
Last answer on 12/1/2021 12:04:35 PM. by
Marta
s.v.mahajan
2072
main entrance for house
Last answer on 5/19/2015 9:07:52 PM. by
charit
1805
main entrance for home
Last answer on 5/19/2015 9:07:45 PM. by
charit
2678
please give images for iron door in front of main wooden door,
Last answer on 11/18/2013 3:27:52 PM. by
nagaraja k.n.
3677
rockklause
anil kumar
3087
mahambaloch
Rohit Patel
2317
vrameshkumar
3406
Dexter
plabita
2265
Anuj Anand
5121
Rinder76
Juliet
1845
Muneeruddin Syed
7104
mohan
2555
Roy
2144
gangula
1821
Ankur
1834
Rahul Bhandari
2074
CalvinWolfe
Priya
5822
Gunja
2676
pritianuj
7307
manisha
kirit
7539
jayant jaiswal
2705
Hari Krishnan
Which are various sources of entrance for termites in a building?
The timber buried in ground. The means of mud shelter tubes constructed over unprotected foundations
Panel doors can consist of one to six wooden panels; but this may be increased.Hollow core wooden doors are usually fo..
