Bricks
How Many Bricks, Cement or Saria Require for 1350 Square ft Plot
Thu Jan 15, 2015
nitin
Topic: How Many Bricks, Cement or Saria Require for 1350 Square ft Plot
I have a Plot in delhi total area 1350 Square Feet any Experienced Person can Tell Me that
How Many Bricks, Cement, or Saria Will require for this can you please provide a estimated budget for above Material, ?
Thanks in Advance
Nitin Rajvansh
coolestnits@yahoo.com
Thu Jan 15, 2015
The total cost for construction would be around 17-20 Lac's. All inclusive in good material. Till Completion.
3076
RCC roof
Dinesh Bhadu
3495
Last answer on 1/10/2012 10:27:59 PM. by
op kataria
Shrinivas
3044
Last answer on 8/18/2011 6:51:51 PM. by
prasadtvp
chella earnest
2863
Last answer on 8/25/2011 5:27:13 PM. by
BATHISHA
2668
Estimate require for new construction
Last answer on 7/3/2020 10:05:34 PM. by
Pradeep Patil
2933
Hello Every 1I want house plan for 1350 sq ft area 22.5 * 60 ft.Double storyGrou
Last answer on 2/18/2014 11:28:50 AM. by
ajmer
1771
House plan problem at gharexpert
Last answer on 7/2/2020 10:03:12 PM. by
Pooja
1876
Last answer on 11/3/2016 10:40:18 AM. by
shashi
2276
swarup chakraborty
1820
I want 15 *50 square ft double house map
Last answer on 5/3/2016 11:33:57 PM. by
pravesh jain
1653
Last answer on 7/3/2015 3:57:17 AM. by
sandeep yadav
8820
Last answer on 7/3/2020 10:16:59 PM. by
sandeep yadav
1992
ground plus one house in 1350 sq.ft
Last answer on 4/1/2013 4:19:58 PM. by
sam (Civil Engg)
T.Harin Kumar
12998
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by
sanjay
Last answer on 6/9/2016 11:04:10 PM. Forum started by
Vignesh
2866
Steel calculation
Vamshidharreddy
2457
estimate
raj
7513
Brick Advice Urgent
pmarple
pmarple
2813
Last answer on 12/31/2020 2:51:38 AM. by
SHAILESH
7513
Brick Advice Urgent
pmarple
pmarple
2880
Bricks
Chandrasekaran S
2794
brick calculation
Last answer on 4/14/2021 6:20:51 PM. by
Gagandeep
2566
Cost of Brickwork
Last answer on 12/31/2020 2:51:43 AM. by
Abhijeet Shinde
4895
Last answer on 8/29/2020 12:29:33 PM. by
Kalayart
Vishal Thakur
2822
srinu
2350
Vikas
3172
bricks
Last answer on 7/3/2020 11:33:47 PM. by
drkksuresh
drkksuresh
5660
Last answer on 7/3/2020 10:43:26 PM. by
sunny420
2014
Last answer on 7/3/2020 9:20:34 PM. by
Alfred
Akshay
3238
Last answer on 6/19/2019 10:21:22 PM. by
Sanzana Hosen
5136
Use of Solid Concrete Bricks
aravind
Kinley Tshering
1625
Last answer on 1/20/2017 3:47:17 PM. by
1341
Last answer on 1/16/2017 3:05:19 PM. by
1846
Last answer on 11/3/2016 2:26:29 PM. by
1480
Last answer on 8/24/2016 12:13:52 PM. by
1797
2968
fly ash bricks
Last answer on 5/26/2016 3:10:41 PM. by
santhosh
2231
Last answer on 5/3/2016 12:34:16 AM. by
sayeedmohsin
1724
Techman
What is acre
Brick Arches
Specification of Brick
