Home -> Forums -> Interior -> Home Improvement -> Marble Flooring for flat
Tue Jan 11, 2011Total posts : 3
pumping iron
pumping iron
Topic: Marble Flooring for flat
Hi all,
I am planning to put a marble flooring in my new flat (Approx 800 Sqft) but my parents have arthritis. I wanted to know if this marble will affect the healt of my parents. They are > 60 years.
Can i put a carpet flooring over the marble flooring if I go in for the marble.
Someone please suggest.
PI
Fri Jan 14, 2011Post  #1
helloaarti21
helloaarti21
Post subject: Marble Flooring Effect
Hi dear,
Marble flooring is very cool by nature. You can go with carpet so that cooling effect of marble will not effect.
Fri Jan 21, 2011Post  #2
Post subject: Marble flooring is expensive
As you know marble flooring is expensive. Why to buy expensive marble if you are planning to use carpet over it.
You have other options such as carpet over tile flooring or go for PVc Wooden tile flooring or Hardwood floors. Hardwood floors does not give cool effect.
Fri Jan 21, 2011Post  #3
Post subject: For persons suffering from arthritis
I recommend you to go for cork flooring. It is best for persons suffering from arthritis.
Please do not choose carpet flooring. It catches dust very easily. So, it would be infectious. Also, the adhesive used for pasting it on the floor is not good for health.
The most important thing is soft flooring. Soft flooring is required. Hard floors create pain in joints and knees. So, Cork flooring flooring is soft.
It is green in nature. It also block sound. It is very easy in installation. There are lot of designs available in it.
Temperature is another different issue. If you are really worried about the comfort of your parents, then choose soft flooring.
Even hard footwear generate pain in knees.
You could install cork flooring, where the usage is maximum.
3389
1602
How much Marole required
2321
Hi my Name is Riyaj khan i am Marble flooring liver incharge for indian Marble,
Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN
2303
marble flooring is done and pop work is over can i start birla putti before marb
Last answer on 7/3/2020 11:35:07 PM. by JAI PRAKASH. Forum started by ashok
1614
flooring white marble in 700sq ft areaestimate plz9718739994
Last answer on 10/4/2016 9:21:30 PM. Forum started by Kamrul
1776
3354
3814
1756
how to design buildings for flats ..say flats with 3 houses in one floor..like t
Last answer on 4/6/2011 7:39:01 AM. by S L Gupta (Civil Engg). Forum started by D.Ramachandran
2403
is it advantageous to buy flat with stilt 2 floors or stilt 4 floors
Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex
1672
Cement requirement
2416
west facing flat on iind floor shd i by it or not,ravi,aurangabad
Last answer on 11/18/2009 5:19:38 PM. by Girish. Forum started by ravi
1843
my flat is on 3rd floor and is SW facingpl advise necessary corrective measures.
Last answer on 12/12/2011 7:39:57 AM. Forum started by poornima
5357
main door vastu question
Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha
5362
2BHK FLAT - TWO PORTIONS - TWO FLOORS - 110 AQ YRDS
Last answer on 1/13/2014 2:21:22 PM. by S L Gupta (Civil Engg). Forum started by Hemant Tiwari
5003
Weathering course
Last answer on 7/25/2014 9:42:13 PM. by JAI PRAKASH. Forum started by Radhika
2221
Tiles or Marble for Flooring
2187
Marble required for flooring
Last answer on 1/7/2022 12:44:11 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
1677
How many sq feet marble needed in 1700 sq feet area with kitchen and two floor stairs.
Last answer on 7/12/2016 10:45:15 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
2361
Refinish a Vinyl Floor
2525
Introduction
1094
Home appliances
2373
2968
layout plan
2182
Window Curtains For Home
3430
Reg: Interior design software
4775
2724
Living Room Decoration Ideas
2242
2040
2219
floor tiles
804
Online dating
2548
4046
Paint vs Wallpaper
2532
Design for a pooja room
9544
Wall Putty and primer
2018
Straight Drop Awnings
2758
Kids Room Theme
2023
sapty tank
Italian
Italian Marble Flooring
Specifications
MARBLE STONE
Marble shall be hard ,sound , dence, and homogeneous in nature with crystal in texture as far as possible.
Terrazzo
White
White Marble
Nowadays marble become to be a favorite material for kitchen countertops, sink tops, floors, and wall tiles. White ma..
