Home -> Forums -> Construction -> Start Construction -> Masonry tool ADZE
Masonry tool ADZE
Wed Oct 15, 2008Total posts : 2
Boovarahan S
Boovarahan S
Topic: Masonry tool ADZE
How does the masonry tool ADZE  look like ? Is there any photo ?
Thu Oct 16, 2008Post  #1
S.Krishnan
S.Krishnan
Post subject: ADZE Tool
Adze is a cutting tool that looks like an axe. The blade of ‘Adze’ is set at right angle to its shaft whereas the blade of axe is set in line with the shaft.
( Adze Tools Used for Masonry Work)
Thu Oct 23, 2008Post  #2
Boovarahan S
Boovarahan S
I didn't ask about the carpentry tool adze.
There is one more masonry tool by name adze.
The picture is like this but I have not seen a real masonry adze. Anybody from Egypt / middle east may be knowing this.
http://www.gharexpert.com/thumb/1023200875826.jpg
1671
tool that add a valveto a 3/4in copper pipeunder pressure
Last answer on 1/17/2014 12:12:34 PM. by S L Gupta (Civil Engg). Forum started by anthony rodriguez
2185
2266
can i know what the tools u used for this pain..its amazing one?!
Last answer on 5/4/2010 7:27:58 PM. by Ajit Tareeka. Forum started by rasha
2405
Where can I find investing tools for cryptocurrency? Does anybody here know the
Last answer on 11/23/2021 7:57:24 AM. by jackthot. Forum started by ?rdyamk
Cost of Foundation
Last answer on 9/11/2012 1:51:22 PM. Forum started by RENJI
1998
Concrete Hollow Block Masonry
2256
1863
Last answer on 1/5/2022 9:14:05 PM. by sanjay agarwal. Forum started by saradha
1878
column
1338
Look for electric paint roller tool ,just got a picture
Last answer on 11/1/2016 12:16:58 PM. by S L Gupta (Civil Engg). Forum started by Isaac
2202
Brick Masonry Columns
Last answer on 1/14/2014 12:50:59 PM. by Ahmed. Forum started by Ahmed
9885
3220
1782
THE ESTIMATOR IN THIS PORTAL IS A VERY USEFUL TOOL WHICH CAN ENABLE A PERSON TO
Last answer on 7/7/2020 12:51:18 AM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
1888
Last answer on 11/29/2021 2:50:23 AM. Forum started by George Mercier
3648
Ghar Expert Estimator Tool questions
Last answer on 7/3/2009 1:11:00 AM. by ksk. Forum started by j smith
3542
Contruction Tool
2507
Need help in valididating whether these rates are normal
Last answer on 1/18/2021 2:10:59 AM. by sudheer. Forum started by r2ipune
3310
Gardening
Gardening Tools
Are you beginner in gardening and don’t know about gardening tools? To properly maintain your garden, you should have ..
Which tools are recommended for Terrazzo flooring?
Tools for Terrazzo Flooring--WOODEN MALLET:- Usually used to knock wooden pieces together, or to drive chisels into st..
The following tools are recommended for door, windows and ventilator frames:
Which tools are recommended for POP?
Finishing trowel: It is used for spreading and leveling plaster on the surface.
Centering
Brick Arches
