Home -> Forums -> Construction -> Cement Concrete -> Mild Steel Bars in Cement Concrete
Fri Jun 05, 2009Total posts : 8
Pujesh Mallick
Pujesh Mallick
Topic: Mild Steel Bars in Cement Concrete
what should be the size of steel bar in stair slab.
The comment above talks about the article   "Mild Steel Bars in Cement Concrete"
Sat Jan 09, 2010Post  #1
NAGENDRA SRIVASTAVA
NAGENDRA SRIVASTAVA
Post subject: Mild Steel Bars in Cement Concrete
IF THERE IS ANY PROCEDURE TO PAINT THE STEEL BARS BEFORE USING IT IN COLOMNS AND BEAMS.
Sat Mar 06, 2010Post  #2
tkalaiva
tkalaiva
I WOULD LIKE TO KNOW HOW MUCH RE INFORMCENT STEEL SPACING REQUIRED FOR Residential build (Indipedent house)
Wed May 19, 2010Post  #3
shivprasad
shivprasad
i am constructed the round wall of diameter 30 feet & 30 feet height & 4.5 inch width,so please say what quantity of material to be use for cement concrete (useing steel).
Sat Jul 24, 2010Post  #4
Ahmed Raza
Ahmed Raza
Herewith i would like to ask the quantity steel, cement, aggregate, water, sand, chemical in per cubic meter for columns or beams. thanks
Mon Dec 27, 2010Post  #5
vijayakumar G
vijayakumar G
Sir, I need the proper detail of mixing details(ratios) for each concrete work & brickwork. Please specify the ratio details of each work
Sat Aug 20, 2011Post  #6
ssrinivasan
ssrinivasan
How to maintain the correct length and line of various columns?
Mon Jun 29, 2015Post  #7
N.S.BISHT
N.S.BISHT
What is the ratio of Cement, crushed Stone& Sand and size of stone in Concrete.
2898
RCC Roof
13755
1944
best material for external grills ,staircase
Last answer on 8/29/2014 2:08:35 AM. by JAI PRAKASH. Forum started by ADINATH
1709
Driveway Reconcreting
Last answer on 1/23/2016 8:41:13 PM. by JAI PRAKASH. Forum started by gpeter
3206
steel
2902
construction cost
Last answer on 4/25/2018 1:08:42 AM. by S L Gupta (Civil Engg). Forum started by Sunil Kumar Singh
1303
1631
1763
1457
3058
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
13772
overlap length to steel
3038
use of tmt bar
2276
1785
1801
How much steel and cementand concrete cement will be required to construct a cei
Last answer on 9/12/2011 1:14:30 AM. by S L Gupta (Civil Engg). Forum started by Raja Bunch
1271
1528
3469
Cost of concrete walls
1792
STP
3651
4349
rate comparison
3203
Concrete Mixture
3142
sloping roof
2090
15805
6470
2379
leakage in new slab
1527
Guide me
5118
2535
Civil Eng Stair Design
2535
Related to Sunken Slab
1857
1998
Concrete Hollow Block Masonry
2414
roof concrete
3199
Ready Mix Concrete
Type
TMT
HSD
Precautions
