Home -> Forums -> Construction -> Foundation -> Minimum thickness of Pile Caps
Sun Nov 06, 2016Total posts : 0
Pritam Thakur
Pritam Thakur
Topic: Minimum thickness of Pile Caps
How much can be the minimum thickness of Pile Caps? The pile diameter is 450 mm. There are is a 3-pile pile caps and 4-pile pile caps.
What can happen if the depth is reduced further ?
7256
2608
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
1778
9040
Absence of Plinth Beam
Last answer on 7/3/2020 9:29:19 PM. by Pritam Thakur. Forum started by Pritam Thakur
2510
PILING in a soft soil
Last answer on 7/9/2012 3:38:08 PM. by S L Gupta (Civil Engg). Forum started by mangeshghule
1967
Last answer on 5/20/2010 8:30:01 PM. by S L Gupta (Civil Engg). Forum started by sudhir
2321
2509
Pile Foundation
1645
Sr I wont to bild 600sq ft on piled house bicose my land is river front 8to10ft
Last answer on 10/11/2015 8:04:12 PM. by JAI PRAKASH. Forum started by ismail
1875
Last answer on 11/3/2016 10:40:18 AM. by S L Gupta (Civil Engg). Forum started by shashi
2445
Last answer on 8/6/2011 2:32:51 PM. by sabina vanjani. Forum started by nita
2357
minimum size of area for bath
Last answer on 3/20/2011 1:47:39 PM. Forum started by DURAISWAMY.G
8879
2865
Steel calculation
2806
8321
2718
2121
Floor thickness
2180
pile work
2684
Pillar
2140
Curing urgent
2371
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1990
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3655
Wall Thickness
2676
3179
13266
Steel Type
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
What is the standard thickness of glass for glass windows?
The standard thickness of glass
ACC
ACC Sheet Roofing
What is the recommended thickness of the under and the top layer of terrazzo tile flooring?
The under layer is made up of cement concrete in 1:2:4 Ratio (1-Cement,2 corse sand, 4 stone aggtregate ) and is aroun..
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
Centering
Iron
Iron Sheet Roofing
