Home -> Forums -> Interior -> Drawing room Doors and Windows -> Mitigate front window blunder
Fri Feb 20, 2015Total posts : 3
Rahul
Rahul
Topic: Mitigate front window blunder
Ok, so I am pretty sure my question falls in interior as well as construction category. Had it been so during construction phase, it could have saved probably lot of trouble. Getting to the point:
Attached is the front window of second floor that we are building. Initially, thought was to create a RCC box for elevation but someone felt that it was not very pleasing and insisted on creating 'C' type window semi-bay window. With not much time to think about future cons we went with it. Here are two catch-22:
1. Window frame is wooden
2. The weathershade (protection during rain!) is not of reasonable dimensions so as to protect the window frame and shutters to be installed. I am from Ahmedabad and we do get fairly heavy rain.
We have not installed window shutters yet and I am told that uPVC and aluminium won't work because wooden frame would swell and contract according to the season. That would cause fitting problem with uPVC and AL shutter and, obviously, you cannot shave those shutters to make them fit. Only option remains is wooden shutter but it would be significantly exposed to the elements.
Your thoughts or input from your experience can help me make right choice.
Thanks very much...Rahul
Attachments: photo.JPG on Fri Feb 20, 2015,&n
Sat Feb 21, 2015Post  #1
The protection above the window is not good. If you cant change the slab above it then avoid the wooden frame or window, otherwise it will gave you issues time to time.
Sat Feb 21, 2015Post  #2
1. Make a new bigger wether-shade upon existing one. Marble or RCC can be used for new shade.
2. Shutters should be wooden only, because you have wooden frames. don't use alumin or UPVC in your case.
Sat Feb 21, 2015Post  #3
Rahul
Rahul
Post subject: Marble weather-shade?
Thanks Jai Prakash and Purvi for your inputs!
@Purvi - Yes, it certainly seems like shutters would have to be wooden. With respect to extending the weather-shade, I am afraid it would become little too thick if its RCC and elevation might take a hit. You mentioned that marble can be also used here which i believe would be little bit more aesthetically pleasing. Would it be possible for you to elaborate little further on placement of marble over the two windows? Also, do you think we should wait first monsoon season to see how things go before making any changes? I am attaching a new pic with a better view. Thank you.
Attachments: new pic window .jpg Sat Feb 21, 2015,&n
Drawing room Doors and Windows-Interior Questions (23)
2838
BAY WINDOW
Last answer on 7/3/2020 11:28:02 PM. by S L Gupta (Civil Engg). Forum started by SACHIN
3952
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
2108
Get me a elevation design for duplex house .ground floor with two large size win
Last answer on 7/3/2015 3:27:25 AM. by JAI PRAKASH. Forum started by Kundan Patel
2181
Comparing uPVC Windows with Wooden Windows and Aluminium Windows
Last answer on 9/11/2010 11:27:22 PM. by sachin. Forum started by Mahendra Agarwal
4013
this is execelant front view,looking varities of front elevation for single sto
Last answer on 12/27/2020 8:48:44 PM. Forum started by Thakur Pattanaik
1925
Dutch Hood Canopy Awnings
Last answer on 1/24/2022 12:11:10 AM. Forum started by Shel Jones
2800
Is it neceesary to have many windows and doors in kitchen as I have got only one
Last answer on 7/4/2020 2:44:00 AM. by PR Jawahar. Forum started by veena
3489
6324
Can anyone suggest front elevation if I upload a photo of front view of my house
Last answer on 7/4/2020 2:05:20 AM. by Ar. Manoj Ralen. Forum started by karuthapandiyan
1751
my plot have south side front, i want to know vastu for my planning house which
Last answer on 5/3/2016 11:38:34 PM. by JAI PRAKASH. Forum started by ROHIT KUMAR
2606
Window position on wall
1967
Last answer on 2/16/2022 8:32:26 AM. by jackthot. Forum started by awdhesh
1497
want window but dont have option to construct window Shajja and not interesred in sliding one
Last answer on 11/12/2021 10:50:56 AM. by S L Gupta (Civil Engg). Forum started by tejaswi
2821
uPVC windows V/s Wooden windows
Last answer on 8/17/2012 12:19:33 PM. by Gunjan Utraja. Forum started by Navneet Shahrawat
2930
Wooden Windows Vs uPVC Windows
Last answer on 7/10/2011 8:45:13 PM. Forum started by Vinod
2981
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
2049
I WANT IDEA FOR FRONT STAIRCASE
Last answer on 8/27/2013 7:22:12 AM. by Ar. Manoj Ralen. Forum started by Er makeshkumar
3051
which windows are better for goa wooden or aluminum sliding
Last answer on 5/30/2013 11:04:45 AM. by S L Gupta (Civil Engg). Forum started by oscar
2197
i want some designs of tower window
Last answer on 7/3/2020 10:25:36 PM. Forum started by Manish
2213
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
1649
Do you have chemical door for bath room size 2'6" x 7' x 2nos if so please advi
Last answer on 7/4/2020 1:58:10 AM. Forum started by Thomas Rodrigues
2104
Honeycomb Doors
Last answer on 4/21/2011 9:21:34 AM. Forum started by venugopal_santhanam
6502
Double shutter main door locks
Last answer on 7/20/2010 9:57:18 PM. by Harish. Forum started by Harish
Hardwood
Hardwood door
Hardwood
Hardwood window
Landscaping
Landscaping for a Small Space
Window
Window Treatments: Window Blinds for Windows
Know about the different styles of window blinds and add style with window treatments such as blinds, shades, curtains..
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
Termite Treatment for windows- Precautions and tips to remember
Termites are major wood destroying insects. We must take every precaution while doing any construction. Here are few t..
Checklists for Doors and Windows
Doors and windows are costly item in house construction and it provides safety, ventilation and adds the beauty and lo..
Window
Window Air Conditioner
When choosing the room air conditioner, size is important. Many people buy an air conditioner that is too large or too..
