Home -> Forums -> Construction -> Raw Material -> Mortar Plastering
Mortar Plastering
Tue Oct 11, 2011Total posts : 3
sunny420
sunny420
Topic: Mortar Plastering
How can we make a good strong mortar plastering...and what r the things to keep in mind for best good strong mortar plastering.
 Also
Is in the market also we can get any good strong mortar plastering material or solution as some companies are selling. if yes which one is best cost and quality wise...
Fri Oct 14, 2011Post  #1
Dear sunny
Cement plastering done on ceiling or walls with 1:3 or 1:4 ratio is good and strong enough, no other market material is required. for good plastering you visit gharexpert.com website of construction where in finishing you will find lot of articles about plastering link given below
http://www.gharexpert.com/articles/Cement-Plastering-1037/Achieve-a-good-quality-in-‘Plastering’_0.aspx
http://www.gharexpert.com/articles/Cement-Plastering-1032/Minimize-defects-in-‘Plaster-Work’_0.aspx
http://www.gharexpert.com/articles/Cement-Plastering-1402/Plastering-0.aspx
Fri Oct 14, 2011Post  #2
sunny420
sunny420
Post subject: First two links r not working
Thank u sir for guiding me..
Sir the links of site  given by u.. only third linkpage  is active and opening...and above two link pages  r not opening ...
Tue Oct 25, 2011Post  #3
Post subject: Dear
Dear sunny
      Links are perfect, I have cross check the links they are properly working, please try again. If you have any problem then write again.
5944
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by S L Gupta (Civil Engg). Forum started by sunny420
1666
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
1894
2924
3207
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
1958
2841
Water seepage from RCC slab
3590
Per Sq:ft rate for flooring
4629
time for paint and wall putty
2438
Gypsum Plaster Vs S/C Plaster
2781
Plaster work
2157
6694
2205
2693
cement plastering
7006
35211
1739
weather proof repair reg
1418
where are use in 20mm plaster
Last answer on 10/22/2016 11:07:01 AM. by S L Gupta (Civil Engg). Forum started by Babasaheb Gite
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11104
2189
2037
Estimate
11123
3073
Steel
3039
use of tmt bar
1642
work turned out by labour
2457
estimate
1762
2992
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1865
2223
zero slump concrete
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
Plastering
Plastering
