Home -> Forums -> Construction -> Steel -> How Much iron/steel will be required for 2600sqft of terrace.
Thu Dec 25, 2014Total posts : 1
pramod Kumar patel
pramod Kumar patel
Topic: How Much iron/steel will be required for 2600sqft of terrace.
Please help and let me know how much Iron/Saria will be required for completing 2600sqft terrace. Everything is completed only upper part is pending.
Please help me in calculating cement bags also(50Kg) for the same surface of area. Thickness will be 5".
Fri Dec 26, 2014Post  #1
Dear Patel
       MS Steel bars quantity is depends upon the design and beam etc. How ever 3200 kg approximate MS Steel bars is required.
For cement if mix is 1;2;4 than 190 bags and if 1;1.5;3 than 260 bags.
2255
Sreel pillars(post)
2892
self made steel home
Last answer on 5/28/2012 8:26:15 AM. by smithjames758. Forum started by Govind.s
1632
2685
steel requirment
722
2866
Steel calculation
1992
what is best for balcony iron railing or steel railing and why?
Last answer on 4/21/2015 11:30:50 AM. by S L Gupta (Civil Engg). Forum started by ashok
Cost of RCC Terrace slab and Colomns
Last answer on 6/10/2014 2:29:45 PM. Forum started by a.monteiro
2083
help
Last answer on 1/9/2015 12:09:16 AM. by JAI PRAKASH. Forum started by Asif
3495
5692
1992
Residential complex
4940
COLUMN AND STEEL DESIGN
4940
5171
2903
construction cost
Last answer on 4/25/2018 1:08:42 AM. by S L Gupta (Civil Engg). Forum started by Sunil Kumar Singh
2186
I want to cover my terrace because of leakage problem during rains.If i want to
Last answer on 9/12/2014 9:53:08 PM. by JAI PRAKASH. Forum started by Akshata Rao
3910
2957
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by S L Gupta (Civil Engg). Forum started by prabhjeet
2685
steel requirment
15583
1992
Residential complex
4370
RCC Columns
3238
7480
Bar Bending Schedule Software
2523
steel
29942
2613
9363
2262
Current iron rod price
2606
1885
Steel Erectors
2382
3268
13772
overlap length to steel
2539
Roof Garden
Type
Iron
Iron Sheet Roofing
HSD
Wrought
Wrought Iron Furniture
Wrought iron furniture is perfect blend of art and beauty. It’s one of the most popular choices of service providers a..
