Home -> Forums -> Construction -> Start Construction -> Mud & brick construction for two story house
Mon Oct 05, 2015Total posts : 6
Prafulla sinha
Prafulla sinha
Topic: Mud & brick construction for two story house
I have a plot near crossing republic (Delhi-NCR, Ghaziabad) Size 50' X 72'. Three side open. 72' side has a wall.
Want to construct a temporary structure (suitable for 10-12 years).
Lot of Labours need a room (1600Rs rent) Size 10' X 12' with common w/c & bath room with hand pump.
In that area generally people errect 9" wall with brick and mud. with cement plaster and steel garter/patti type slab. So that when they dismental the construction, bricks are re-used and iron are sold.
or should I go for precast building???? Cost wise.
or any new idea???
In that area all the lobour camps are made as single story, just thinking for two story with low quality cheap slab.
My plan is to use this as rental purpose for 10-12 years then dismental and construct RCC floors (G+5) and start business as builder.
Suggestions are requested on floor plan as well constuction and cost etc.
Mon Oct 05, 2015Post  #1
For plan check the house plan section or contact the team for the same.
Costing would be around 600-700/sq.ft of the covered area per floor.
Mon Oct 05, 2015Post  #2
Prafulla sinha
Prafulla sinha
Thanks for reply.
Please re-check,
It is simple construction, for 10-12 years.
It is for lobor coloney or student's lodge type.
Please re-check.
I am expecting Rs400-450 psf in total because of mud use in wall brick jointing. normal flooring.
Mon Oct 05, 2015Post  #3
Flooring?
Wall work/
Electrical & Plumbing work?
Share all the details and lets finalise.
Tue Oct 06, 2015Post  #4
Prafulla sinha
Prafulla sinha
This will be a labor camp.
Common W/C & bath room
Only hand pump.
general electrical wiring with three points in each room.
01 there will be only Panna Flooring.
02. No plumbling (Only Common W/C & bath). Only hand pump.
03. Brick works with mud (So that bricks can be used, when we break this construction after 10-12 years).
04. Above the brick work. Plaster of cement/sand (Thin & low gread).
05. Temporary construction for 10-12 years.
06. After that we will break the construction and sell the land to builder.
07.  Slab will be girter patti type. Cheap and best for temporary construction.
Tue Oct 06, 2015Post  #5
Share your calculations plz for future use.
Wed Oct 14, 2015Post  #6
Prafulla sinha
Prafulla sinha
shinninglikeme ji,
I am looking for temporary structure for 10 years.
After that will recover the bricks ......some money will be recovered.with steels and bricks.
3825
3620
4353
2404
4088
2046
1650
please send me south facing elevation of two storied building
Last answer on 5/19/2016 12:34:23 PM. by S L Gupta (Civil Engg). Forum started by jakeer
2949
1819
Last answer on 4/6/2017 10:05:57 PM. by Saurav anand. Forum started by prashant
2777
I have a 32'x30' Corner Plot
Last answer on 7/19/2018 1:52:04 AM. by S L Gupta (Civil Engg). Forum started by Hari Darshan
6807
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
6088
What is construction cost
2970
Nubian vault and rains
Last answer on 12/31/2020 1:57:20 AM. by H S Rathi. Forum started by Boovarahan S
1802
2144
2687
type of brick
1382
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
1779
KINDLY SEND 24* 45 CORNER HOUSE FRONT AND CORNER ELEVATION 3 STORIES
Last answer on 2/7/2017 12:59:59 PM. by S L Gupta (Civil Engg). Forum started by balwinder singh
6688
13*40 2 bhk 2 story east face .please mail the house map
Last answer on 7/4/2020 3:04:42 AM. by Beenu Phogat. Forum started by Devyani
2451
3273
3284
4429
3975
2197
2699
4210
5167
2378
2294
1996
2447
2114
3194
2046
12514
2164
2010
2726
Why
Brick Arches
