| Basement Walls Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for.. |
| Demarcation/layout Procedure Baseline is marked on the ground either from centre line of the road or from any permanent building nearby |
| Why an Architect should be hired? We recommend that an architect should be appointed for the construction of any house as the professional help would be.. |
| Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. |
