What is the checklist of cable lay out in home? Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident.. |
| 10 things to check before the rain hit your home! Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr.. |
Earth Filling Each layer of earth should be rammed and consolidated while filling it around ‘Brick Masonry’. |
| Precautions during Fabrication and Fixing of Window Grill. Any small carelessness during fabrication works can deform the shape of steel doors and windows etc. Fabrication shoul.. |
