Home -> Forums -> Construction -> Vastu Shastra -> My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion o
Tue Mar 25, 2014Total posts : 1
hemant yogi
hemant yogi
Topic: My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion o
My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion of 2bhk . First floor for complete 3bhk with extra facalities.
Thu Mar 27, 2014Post  #1
DearYogi
Vastu Shastra-Construction Questions (38)
2648
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by Gopal Upadhyay
19871
16/45 plot size....give a best plot map
Last answer on 10/27/2016 2:18:00 PM. by Beenu Phogat. Forum started by piyush ji srivastav
2687
Last answer on 8/8/2017 11:53:36 AM. by S L Gupta (Civil Engg). Forum started by ameer singh
2529
duct size for and kitchen
Last answer on 7/3/2020 11:52:01 PM. by seema tyagi. Forum started by Yogender Singh
22183
Difference between plot size area, built-up area, plinth area
Last answer on 3/17/2016 12:21:27 PM. by S L Gupta (Civil Engg). Forum started by vamsi
2154
Last answer on 2/24/2021 1:43:22 PM. by Beenu Phogat. Forum started by Sagar
2369
Last answer on 7/23/2009 8:04:51 PM. by Amit Hasija. Forum started by sawapnil kumar
2518
New house construction
Last answer on 12/1/2020 3:51:35 AM. by kawalnain kaur. Forum started by kashinathan
21315
25by 50 plot aria so please give me drawing map with vastu and include car
Last answer on 1/10/2016 8:57:19 PM. by JAI PRAKASH. Forum started by santosh
3577
north facing plot map size 25*50sqare yards
Last answer on 6/15/2013 8:58:08 PM. by arvintacker. Forum started by anjani sharma
9061
makan map
1839
dear sir, my plot size is 15x40, pls send map dissing
Last answer on 2/4/2021 6:57:06 AM. by S L Gupta (Civil Engg). Forum started by avdhesh mishra
1870
dear sir my plot size is 15x40,east facing pls send map dissing
Last answer on 1/2/2021 5:25:37 AM. by Beenu Phogat. Forum started by avdhesh mishra
1655
our plot size 38*50 pls house constration map
Last answer on 10/15/2016 6:16:55 PM. Forum started by RAMESH KUMAR
2493
need 22.5 x 15 size plot map
Last answer on 9/2/2017 12:43:54 AM. by S L Gupta (Civil Engg). Forum started by bhupendra1174
3140
house map for east south facing 17 x 46
Last answer on 6/5/2017 12:47:02 PM. by S L Gupta (Civil Engg). Forum started by mahesh
Plot size 30-41 north facing send me map by vastu
Last answer on 7/6/2015 11:04:52 AM. by seema tyagi. Forum started by rakesh bhata
1527
hlo sir, my plot size 15x45, please guide me a better house map.
Last answer on 9/2/2020 12:40:53 AM. by S L Gupta (Civil Engg). Forum started by pramod
2293
Kindly suggest ground plus 1 map for 120 Sq yards east open plot
Last answer on 7/4/2020 4:21:37 AM. by S L Gupta (Civil Engg). Forum started by Yousuf
3574
2288
I have not received any sggestion regarding my earlier question about our flat n
Last answer on 10/12/2021 6:24:29 AM. by Priti Arora. Forum started by subrahmanyamkvs
2718
i in kuwait and iam stying in one room where to keep cash box?
Last answer on 9/7/2021 3:50:41 AM. by Kaliopsy. Forum started by rafimeer
2398
pl send me40feetlenth 30feet berth plot, 850feet(or)900feet 2bhk north(or)east f
Last answer on 8/24/2021 3:22:22 AM. by S L Gupta (Civil Engg). Forum started by nagarajan.n
3368
2936
I need layout for making duplex for east facing plot 30 x 50 bedrooms with attac
Last answer on 2/26/2021 4:04:46 AM. by S L Gupta (Civil Engg). Forum started by devinder
3071
can a vastu expert go for bet for best results by vastu remedies ?
Last answer on 2/25/2021 4:27:09 AM. by S.Krishnan. Forum started by harbans singh sekhon
2402
hi ............... i want bed room cupbords designs,plese sand me.
Last answer on 2/8/2021 11:49:19 PM. Forum started by vijay
5533
Last answer on 1/26/2021 5:40:38 AM. by VastuMoorthy. Forum started by srihari pagadala
2496
Your name :Srinivasan Email adds:vasan09@gmail.com
Last answer on 1/18/2021 9:48:48 PM. by seema tyagi. Forum started by Srinivasan
3991
Last answer on 12/31/2020 2:45:49 AM. by VastuMoorthy. Forum started by senorita
2985
My Plot size is two sides open with two roads at southeast & northeast side of p
Last answer on 12/31/2020 2:31:46 AM. by harbans singh sekhon. Forum started by kstomar2001
3844
Last answer on 12/31/2020 2:29:53 AM. by POSAM BHASKARRAO. Forum started by Sanjeev Saran
2812
Last answer on 12/31/2020 2:14:53 AM. by krishna. Forum started by trisha
2870
Last answer on 12/31/2020 1:54:01 AM. by prasad. Forum started by kalpana sharma
6198
Vastu and Brahmasthan
2023
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
1899
Kitchen is in south east and dinning in west. It won't work.
Last answer on 7/3/2020 11:38:06 PM. by S L Gupta (Civil Engg). Forum started by ashok
2133
my date of birth 01-06-1958 vich is my good direction pls
Last answer on 7/3/2020 10:55:27 PM. by S L Gupta (Civil Engg). Forum started by anjaneya
Preliminary
