Mon May 20, 2013Total posts : 1
Murtaza
Murtaza
Topic: NEW TERRACE HAIRLINE CRACKS IN MORTAR
Have relaid the top layer of our terrace floor with a cemnt sand mix of 1:4 alongwith waterproof compounds.
Curing was doen by waterfilling for 10days.
I now find that the top layer has hairline cracks in many places.
My contractor it is normal and now nothing can be done and there will be no issues.
I am worried that these cracks will widen with time and also there will be leakages.
Can the same be filled by crack fillings or some other solution and will this be a permanent solution.
Wed May 22, 2013Post  #1
Dear Murtaza
         Your query is not clear, on what base you laid cement sand mix 1;4 write in detail.
In my view you laid cement sand mix 1;4 on brick tile terracing and which shows cracks on top, if this the position than do not worry , if the mix is thin than it will  remain long time and if it is thick than it will be break after some time.
   But if tile joints are filled properly than there would be no leakage. no need to fill the cracks.
2842
Water seepage from RCC slab
3134
6881
3565
Polimer fibres in mortar
Last answer on 8/23/2010 4:06:36 AM. by Girish. Forum started by Shridharan
2997
2914
Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya
1667
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
1895
2503
1970
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
3077
Water Harvesting System
2925
2487
Exterior Wall Crack Repair
Last answer on 12/26/2011 7:13:39 PM. by S L Gupta (Civil Engg). Forum started by S. Kumar
2059
Cracks in my new house
2898
Terrace water proofing
5944
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by S L Gupta (Civil Engg). Forum started by sunny420
1959
3207
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
24
28
Roof Garden
How To Repair Cracks
Happy
Happy New Year 2009
Surface
