Fri Mar 21, 2014 | Total posts : 1 |
| Topic: Need Advice on Solid Wood Floors
Can i use mixture of water and vinegar to clean solid wood floor? |
Mon Mar 24, 2014 | Post #1 | Abhishek Garg (Builder & Engineer)
Join date: Apr 2013 | Dear Chintan: I am assuming you are talking about hardwood flooring and not laminate flooring. For hardwood flooring, you should not take risks while cleaning. Whatever method you choose to adopt after reading this post, do try it over a less visible small area first. For routine cleaning use general tap water or filter water which is ph-neutral i.e. neither acidic nor alkaline. For grease and dirt, use alkaline water i.e. with soap, detergent or baking soda dissolved in water. For other deposits, use acidic water such as white vinegar in water. Do not use ammonia, bleach, harsh cleaners or residue leaving cleaners like oil, wax etc. Wipe the floor absolutely dry afterwards.
In case your floor is very old, only use a cleaning spirit as the surface coating for surface-sealing may not be water and stain resistant. I hope it helps. | |
Wooden flooring-Construction Questions (25) | |
Articles that might interest you! | | Cedar Wood For any construction wood is very major raw material and Cedar wood is one of most common type of wood to be used maki.. | | Wood Roof Shingles Wood roofing is probably one of the roofing materials you are considering. Warm and elegant look of wood roof makes it.. | | Hard wood Characteristics and application Hard wood is one of the major resources for wooden flooring today. You must know hard wood specification before buying.. | | Water for Construction Pure and hygienic water is not only important for our life but also needed for quality construction. From the foundati.. | | Teak wood frame Teak wood frameTeak wood door and window frame are used in Hotels,Rest House,Temples, Ban glows & other. | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | How to level concrete sub floor before installing wooden block flooring? The recommended method for leveling of concrete in wooden block flooring is described in the writeup. | | Finishing recommended for wood ceiling There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w.. | | Garden Furniture Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, .. | | Dining Room Ceiling Dining room ceiling designs can change the interior of your room. A white ceiling in your well furnished home looks du.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
