Home -> Forums -> Construction -> Outdoor -> Need the Deatiled Land/Cost/Material Estimate for Marriage Function Hall
Wed Jul 29, 2015Total posts : 2
shankar
shankar
Topic: Need the Deatiled Land/Cost/Material Estimate for Marriage Function Hall
       I have gone through your website and found very interesting. I think this a very good place to get valuable information and help.
We are planning to construct a A/C wedding hall in Andhra Pradesh (Near Kurnool). Capacity of the hall should be around 400 people and it should have atleast 6 to 8 guest rooms, Kitchen and dining hall
Need the estimate for the required land to accommodate the above request and the cost estimate including the Centralized/de-centralized A/C unit. along with other things for kitchen and dining hall
My initial expectation of the hall area is around 10 Cents. but please provide all your advises and cost and material estimates.
Thanks, Shankar
Thu Jul 30, 2015Post  #1
         Cost of building is depend upon the plan of building and specification adopted during construction, elevation and height of building, Type of floor, thickness of slab, size of column etc. These all things have effect on the rate per sft.If I say any rate on the hit and trial method that serves no purpose. If You have  estimate than you will be in better position to deal the contractor. In my view if you spent a small amount on proper planing, estimate etc which will benefit you more.If you want the service of gharexpert than see the link below or contact at suppot@gharexpert.com.
Wed Aug 05, 2015Post  #2
The construction part will cost you around 1500/Sq.Ft. for the covered area.
It does not include the landscaping work which you may need for open space.
The centralized AC plant will cost you around 10 lac's extra.
The area you need is minimum 10000-15000 Sq.ft.
7043
marriage function hall
Last answer on 6/9/2021 6:32:54 AM. by KAMAL KOLLURU. Forum started by arul
6101
Function hall
Last answer on 10/4/2021 2:49:58 AM. by Lola Cooper. Forum started by Siddharaj
24376
Estimate to build a Marriage Hall with 2 floors
Last answer on 7/4/2020 12:12:50 AM. by Manikandan. Forum started by Senthilkumar Kanagaratihnam
3921
need for plan
5956
Marriage Hall Construction
Last answer on 7/21/2021 4:45:40 AM. by Alexander Graf. Forum started by baskar20
4106
Last answer on 6/15/2021 7:30:34 PM. Forum started by baskar20
12980
Last answer on 7/4/2020 1:57:10 AM. by harshit agrawal. Forum started by baskar20
4295
Last answer on 9/9/2021 12:31:10 AM. by S L Gupta (Civil Engg). Forum started by baskar20
4601
Last answer on 10/12/2021 1:06:34 AM. Forum started by baskar20
4243
Last answer on 9/17/2021 1:48:12 PM. by . Forum started by baskar20
12192
Last answer on 2/27/2021 2:53:51 AM. by Ar. Manoj Ralen. Forum started by baskar20
2518
Function Hall
3944
Hello,Could the experts suggest me Vastu for Wedding hall (marriage hall) please
Last answer on 12/31/2020 2:26:42 AM. Forum started by kamalesh
51315
Construction cost for new Marriage Function Hall
Last answer on 9/3/2021 12:34:50 AM. by ravi at Dalmia. Forum started by abdul rahman
4070
marriage hall drawing with cost . i have plot 110.00 feet 110.00 feet north face
Last answer on 11/12/2021 1:58:45 PM. by JAI PRAKASH. Forum started by senthilkumar
6112
Last answer on 10/5/2021 3:01:31 AM. by Alexander Graf. Forum started by ravi garg
4961
Marriage hall
Last answer on 7/3/2020 11:49:25 PM. by JAI PRAKASH. Forum started by PRAVINKUMAR.T
5245
I am planning to built a marriage hall in 7500 sqft open space in coimbatore . 1
Last answer on 10/14/2021 9:24:37 AM. by Alexander Graf. Forum started by PRAVINKUMAR.T
2288
Looking for architect with experience in Function Hall plans
Last answer on 2/15/2022 5:04:04 AM. by JAI PRAKASH. Forum started by faiz
2844
Steel calculation
1744
6661
6302
10592
Life span of RBC lintel roof
2080
Foundation
3558
R.C.C. column in Sqft
2268
Plumbing works
1568
2130
New 4 storey building design
1881
earth filling under floor
1763
want a parking
2385
2255
2557
foundation plan.
Last answer on 12/15/2011 2:31:13 PM. by Ishmael Mphande. Forum started by Patrick Salasini
2607
Last answer on 12/6/2011 7:58:37 PM. by Manish. Forum started by Manish
2489
Re-Construction
2991
cracks in walls
Balcony
Balcony is an extended platform that projects from a wall(interior or exterior) of a building, supported by columns an..
Why
Proper
Specification of Brick
Fire
