Need Valuate the building
Thu Sep 03, 2015
Hanumantha
Topic: Need Valuate the building
Hello All,
We are planning to purchase a built house site measuring 30*18, a 3 storey building built 10 years back without pillers, Normal flooring, No additional fittings in the building, only fitted with tube light and fan, kindly valuate the only building part with calculation details., total build up area is 1450,
Thanking you,
Hanumantha,
Bangalore.
Thu Sep 03, 2015
Its good to check the rates in that area of the same king of building on a real estate website. The construction cost on present rates will be aroun 15 lac's for the same.
Fri Sep 04, 2015
The cost of the building can be calculated with the help of plan of building and specification used in the building. For normal specification the cost may be Rs 800-00 to Rs 1000-00 per sft. But as stated by you the building is 10 years old so there is 10% depreciation in the cost.
1875
i need 15 feet building elevation and only ground
Last answer on 5/24/2016 3:32:43 PM. by
waseem
804
Last answer on 10/7/2020 11:58:13 PM. Forum started by
S NAGARAJAN
2913
please i need an interior decoration cataloge showing all the pop desings in the
Last answer on 1/21/2011 11:13:26 PM. by
emmanuell
2827
ESTIMATION
Last answer on 10/17/2012 4:20:51 PM. Forum started by
AHAMED YUSUFF
2330
Last answer on 7/3/2020 10:02:44 PM. by
mohammed yousuf
May I know the max excavation needed for G+2 building?
Last answer on 7/23/2013 2:28:34 PM. Forum started by
ananthasakthi
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by
sandeepkelkar
2874
cost of rcc slab
Last answer on 12/26/2013 11:30:08 AM. by
abdul wahid laskar
3845
comments required
Last answer on 11/18/2021 7:51:18 AM. by
gangula
2593
Rain Water Harvesting
Last answer on 2/7/2022 9:00:21 AM. Forum started by
naveenti@gmmail.co
3501
Paint selection
Last answer on 7/3/2020 10:41:47 PM. by
Messi1999
anwar
2042
It need to thinks for middle class people with innovative ideas to build such ty
Last answer on 12/12/2010 12:25:15 AM. Forum started by
S Borthakur
2112
i have a plot between twin city at orissa measuring area 3000sq ft.i need a buil
Last answer on 7/15/2010 6:03:32 PM. by
siddharthtongya
kunmun mishra
Help required for construction of basement+ stilt+ 3 floors on 205 sqyd plot in huda gurgaon sector
Last answer on 3/16/2017 10:24:00 PM. Forum started by
Mukesh
2846
Construction of new office bilding
Last answer on 2/22/2022 6:39:38 AM. by
Anupam Anurag
sushil singh
1853
Need suggestion on building a strong house.
Last answer on 4/22/2014 2:28:20 PM. by
gharsami
1369
Need advice for constructing commercial building with a pent house
Last answer on 9/9/2016 11:42:58 PM. by
bhuvaneshwaran bn
Mini
Last answer on 10/14/2016 7:41:24 AM. Forum started by
Sunil
1497
Need an opinion on a home built on a hill
Last answer on 7/3/2020 10:41:36 PM. by
rernest
rernest
Orientation of Building
Cupola Proportions
Tips for cupola proportions
How to Design a Garage
