Home -> Forums -> Vastu -> Drawing Room -> Need help fitting in an internal staircase into this design
Wed Oct 10, 2012Total posts : 2
Sundara
Sundara
Topic: Need help fitting in an internal staircase into this design
Hi all,
I have finalized the following design for my one floor independent house....I have followed vastu principles where I can and want, especially entrance in NE corner, kitchen in SE corner, puja in NE/E, bedroom in SW, bathroom in W etc. I am planning for a water tank in the SW corner on the terrace. My question is : the staircase is obviously wrongly placed as per vastu and needs to be in SW/W areas. However, I am unable to place it in a way where it is accessible from the hall and at the same time I retain the bedroom where it is - open to the E and S sides for morning sunlight and aeration (my plot will have trees in all of East and South).
Can forum members please help me with this?
I know there may be errors in my vastu compliance. Please point out any vastu issues only if it is major, as hearing anything negative about my almost final design, as you can understand, can upset my sentiments about the design.
Attachments: FinalDesign.jpg on Wed Oct 10, 2012,&n
Wed Oct 10, 2012Post  #1
Sundara
Sundara
Post subject: Clariication
Just to clarify - the red lines in the attached are windows and the blue lines are doors/french doors....... small white squares are columns.
Wed Oct 10, 2012Post  #2
krishna
krishna
Post subject: INTERNAL STAIRCASE
locate the  stairs at SW corner of the hall, which will be more convenient and also satisfies vaasthu
2166
Last answer on 3/5/2016 9:14:04 PM. by JAI PRAKASH. Forum started by gulam yazdani
3133
false ceiling
2394
hi, i am sunny....i need some help in designing a lcd unit with some light effec
Last answer on 12/10/2011 6:45:54 PM. Forum started by sunny
1617
suggest layout 36fit by 60 fit
Last answer on 5/29/2015 10:34:14 AM. by seema tyagi. Forum started by Ashish
2107
How to design easy staircase model
Last answer on 8/9/2013 11:08:51 AM. by S L Gupta (Civil Engg). Forum started by jk
6162
i want structural design of staircase in area 3.00mx 2.20 m
Last answer on 5/3/2014 7:45:54 PM. by Navneet Jharia. Forum started by sudipta das
1853
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
2182
Last answer on 7/20/2015 7:12:25 PM. by JAI PRAKASH. Forum started by rishi
3409
i have a plot of size 27'* 60 i want to make on this a beautiful house i need ur
Last answer on 11/24/2021 5:22:20 AM. by ravi at Dalmia. Forum started by jagmeet singh
2707
Living Room Chairs
Last answer on 12/31/2020 2:11:52 AM. by Elizabeth Mixson. Forum started by Urvi
2437
Need Help internal walls cracking horizontally, diagonally and vertically
Last answer on 7/14/2014 2:25:04 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
12582
pooja room under staircase
Last answer on 2/27/2011 9:42:19 PM. by Simon. Forum started by Raju
2606
Window position on wall
3122
Dining Room Ceiling
Last answer on 7/2/2020 8:51:19 PM. by O'SirTee. Forum started by atiq khan
2932
Help on Staircase and Elevator design
Last answer on 7/3/2020 10:46:12 PM. by S L Gupta (Civil Engg). Forum started by Dev
3343
Tips for Office Furniture
Last answer on 1/8/2022 3:03:34 AM. by Sandy Parker. Forum started by 3guptaanurag
3258
remedy for staircase
Last answer on 3/5/2021 2:01:11 PM. by Amit Hasija. Forum started by ruchi
3889
1962
Need feed bck rg. the Kitchen over the upper staircase.
Last answer on 2/24/2013 10:23:20 PM. Forum started by ram
3676
3086
2316
2345
3406
2265
5121
1845
7104
2554
2143
1723
1821
1833
2073
5822
2676
7305
7537
2704
Staircase
Staircase railings
How to Design Stairs?
Stairs
Stairs Design
Earthing
