Home -> Forums -> Construction -> Layout and House Plans -> Need help in estimating wood requirement for 2BHK home (1400 s.ft approximately)
Wed Dec 29, 2010Total posts : 2
Mohan
Mohan
Topic: Need help in estimating wood requirement for 2BHK home (1400 s.ft approximately)
Dear All,
     Am looking for a information on wood requirement for a 2BHK home (approximately 1400 s.ft). I have enquired about the rates of various kinds of wood normally used for residential home construction in southern part of India and have taken quotation for the same. Now Am in a need of approximate CFT requirement for my home, so that I can decide on the kind of the wood to be used ( as I I have allocated a fixed budget for wood expenses and would like to contain the expenses within the budget allocated). Any chart or pointer to the document which talks about the wood requirement breakups like... CFT needed for 8x6 window, normal 7x3 door, regular 6x4 cot...etc., would be really of great help. Requesting you to provide me some pointers on this direction. Many thanks in advance.
Thanks & Regards,
Mohan.
Fri Dec 31, 2010Post  #1
Dear Mohan
              For calculating quantity of wood, plan of the house or building is required because there are variation in nos of door and windows according to planning and site conditions. You should sent your house plan at support@gharexpert.com with the size of doors and windows.
Fri Dec 31, 2010Post  #2
Mohan
Mohan
    Thanks for the reply; I did not have a soft copy of the plan with me; So please find the details of the doors and windows below:
Sl.NoDescription  Numbers  Dimension (in ft)
 1  Doors 1 Main door
+ 5 doors
1 pooja room
7x3
 2  Window1  3  8x6
 3  Window2  7  3x6
 4  Window3  3  4x3
Requesting you to guide me and provide me some guidance on estimating the wood requirement. Many thanks in advance.
Thanks & Regards,
Mohan
191901
804
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
3130
2383
I need 16*40 home sketch with vastu please help me
Last answer on 4/25/2013 10:39:22 AM. by Amit Hasija. Forum started by Sharath
5177
RCC Lintel , cast and material esitmate
Last answer on 7/3/2020 10:47:13 PM. by S L Gupta (Civil Engg). Forum started by ndmalam
15808
2435
2746
2275
Last answer on 9/25/2021 12:44:28 AM. Forum started by abid_baig@yahoo.com
1644
hi sir,give me bdjet for my home 2bhk 1000 sqft.plz
Last answer on 8/30/2016 11:39:48 AM. by S L Gupta (Civil Engg). Forum started by Harish Pawar
1181
2441
2125
Cost of Construction
Last answer on 8/19/2013 11:11:40 AM. by S L Gupta (Civil Engg). Forum started by Naveed Mohamed
15215
My engineer has provided door and window details, how to calculate the requireme
Last answer on 12/25/2020 3:28:55 PM. by subhakankhi. Forum started by shekar
1973
Elctrical wiring
5027
600 SFT ACC 2BHK Costing
Last answer on 7/4/2020 4:20:53 AM. by JAI PRAKASH. Forum started by bharadwaj
2338
I want a residential home design low estimate
Last answer on 4/23/2013 11:32:19 AM. by S L Gupta (Civil Engg). Forum started by Dipankar Gharami
2691
2924
2188
2184
2793
4520
1890
2284
2266
2767
3464
2356
1967
2242
3595
2324
2091
2792
1548
2114
What is acre
Cedar Wood
Wood
Wood Roof Shingles
Hard
Teak
Teak wood frame
Finishing recommended for wood ceiling
There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w..
Why
