Wed Oct 21, 2009 | Total posts : 2 |
| Topic: Need help in valididating whether these rates are normal
First of all congratulations and thanks to the founders of this website. It has a lot of useful information and its estimator tool has lot of potential. Excellent job..
My wife and I are getting our home constructed in Pune. Its a three level house (including ground level) with interior space of approx 3100 Sq ft. The construction started almost two years ago and so far what we have is a shell of the house (RCC, brick walls, interior/exterior plaster, compound walls, over head water tank, under ground water tank etc). We hired a contractor who takes 12% over the cost (material + labor) for his supervision work. Currently, we live abroad, so the contractor also bought materials on our behalf. I'd really appreciate if someone can validate/verify some of the labor charges I received lately are the normal labor rates for Pune:
* Overhead water tank (10,000 lit) @ Rs 9.25/lit * Underground water tank (10,000 lit) @ Rs 9.25/lt * 9" Brick masonry work @ Rs 95 / cft * 6" Brick masonry work @ Rs. 65 / Sq ft * Internal plaster @ Rs. 21 / Sq ft * External plaster @ Rs 36 / Sq ft * Water proofing for toilets @ Rs 71 / Sq ft * Water proofing for terrace @ Rs 64 / Sq ft * Water proofing for water tanks @ Rs 34 / Sq ft * Masonry for compound wall @ Rs. 64 / cft
We'd really appreciate if someone can validate this. I wish I found this service two years ago, as I would have used the architectural service thats being provided. We paid our current Architect Rs 2 lakh and I still do not have final drawings.
R2IPune
Fri Oct 23, 2009 | Post #1 | Tip Master
Dear Sir
Thanks a lot for your encouraging feedback. At GharExpert we try hard to make sure that the content and service are helpful to the readers and brings transparency to the whole home construction process.
1. From your details, it seems that the rates of items given are with material and labor both. 2. The rates seem to be on higher side. 3.Can you send us the agreement you had with your contractor? 4. Can you email us the architectural drawings that you have? 5. Please also send the pictures of the current site so that we understand the current work situation.
You can email details to Support@GharExpert.com Once we get the details we’ll send you a list of our further services and quotes for the same.
Gharexpert Help desk
Wed Nov 11, 2009 | Post #2 | sudheer
Join date: Jul 2009 | Post subject: increasing the height of existing compound wall
Dear Sir, Iwant to increase my compound wall made of bricks with plaster.I want to increase the height by another 3ft.The compound wall is 126ftlong and 56ft in front and about 12 inches thick..The total construction will be about1092sq.ft. there are two doors ,one 12ft wide and another 4ft wide.Can you tell me the approximate construction cost and rates to complete the job. I have been given an estimate of RS-194000 by Dr.Palkar.
Articles that might interest you! | | Analysis & Rates The capacity of doing work by an artisan or skilled labour in the form of quantity of work per day is known as the tas.. | | Labor Contract vs. material contract In building construction work, there are many aspects or things to be done by building owner such as arranging drawing.. | | Help you to Choose Best Material for your Garage Door Choosing a garage door requires consideration about material, finish and its appeal. Garage doors are available in dif.. | | Why an Architect should be hired? We recommend that an architect should be appointed for the construction of any house as the professional help would be.. | | Proper Ventilation Proper ventilation freshens our breaths and leads us a healthy life. If you design or modify the house with maximum ve.. | | What is the recommended temperature and the rate of flow for the supply of hot water(storage type of installation) to various fixture? To minimize the danger of blistering, risk of steam formation etc. Storage temperature of 60 degree C is recommended. .. | | Purchasing Guidelines for Coarse Aggregate Sub standard material reduces the strength of RCC, Reinforced Cement Concrete, by 10 to 30 %. Use these steps to ensur.. | | Through rate-contractor; guidelines for better relationship! Everyone wants to build a dream home but no-one wants the hassle that comes in day-to-day construction work. Here are .. | | Importance of Proper Water Supply and Sewerage during construction Construct Sewerage and Water Supply of your house properly else you have to face many hygienic problems.Generally it i.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
