Home -> Forums -> Construction -> Start Construction -> Need help to calculate buiding cost
Sun Feb 15, 2015Total posts : 2
astala
astala
Topic: Need help to calculate buiding cost
Please let me know the cost for the below
1) External staircase with 19 steps 3 feet wide for the ground floor house the staircase have basement same as portico and one pillar for staircase landing. There no headroom there is no handrails. I am going for SS staircase and I will borne the cost for it separately. I suppose it should be less than the building sqft rate
2) Cost for septic tank some say it will be charged on litre capacity eg 12 rs then 12 rs X 6000 litre = 72000 rupees
3) cost over head tank SLAB (4X4) height 3 feet on the corner of parapet wall with a supporting pillar made of brick. its only slab as I have sintex tank.
4) Already compound was present so Increased the compound height by 1 sqft on backside which is 30 running sqft. Moved front compound main gate by 10 feet to right side so 10 feet compound wall of 6 sqft height and 10 feet wide it has basement already. Then 2 new compound pillars of 1.5 sqft dimension height 7ft with basement.
5) Cost for Ramp for car park height 4ft sloped to road wide 10 feets below it 4X10 for collecting was water this is not plastered as the water needs to be drained/observed.
6) Cost for car park/portico has been said will be same price of the building sqft rate in this case I assume it should include the carpark tiles also.
7) Cost for elevation Arch design in portico measuring 3 ft max to 1 ft min from ceiling. Area is 30 running sqft
8) what will be the cost for floor tiles and bathroom tiles for contract signed in june 2014. I have it for 40 rupees for floor tiles and 30 rupees for bathroom including transport. when I checked in shop there is no branded floor tiles available less than 52 rupees.
Sun Feb 15, 2015Post  #1
astala
astala
Post subject: forgot to mention location it is for chennai loc...
forgot to mention location it is for chennai location
Sun Feb 15, 2015Post  #2
1) External staircase with 19 steps 3 feet wide for the ground floor house the staircase have basement same as portico and one pillar for staircase landing. There no headroom there is no handrails. I am going for SS staircase and I will bear the cost for it separately. I suppose it should be less than the building Sq.Ft rate = 19 x 3.25 = 61.75 x 400 = Rs. 24700
2) Cost for septic tank some say it will be charged on litre capacity e.g. 12 rs then 12 rs X 6000 litre = 72000 rupees = the min would be 10 Rs/Lt. = Rs. 60000
3) Cost over head tank SLAB (4X4) height 3 feet on the corner of parapet wall with a supporting pillar made of brick. Its only slab as I have sintex tank. = 4x4 = 16 x 400 = Rs. 6400
4) Already compound was present so Increased the compound height by 1 Sq.Ft on backside which is 30 running Sq.Ft. Moved front compound main gate by 10 feet to right side so 10 feet compound wall of 6 sqft height and 10 feet wide it has basement already. Then 2 new compound pillars of 1.5 Sq.Ft dimension height 7ft with basement. = 7x1.5 = 10.5 x 400 = Rs. 4200
5) Cost for Ramp for car park height 4ft sloped to road wide 10 feet’s below it 4X10 for collecting was water this is not plastered as the water needs to be drained/observed. = Rs. 4000
6) Cost for car park/portico has been said will be same price of the building Sq.Ft rate in this case I assume it should include the car park tiles also. = Yes
7) Cost for elevation Arch design in portico measuring 3 ft max to 1 ft min from ceiling. Area is 30 running Sq.Ft = Rs. 36000
8) What will be the cost for floor tiles and bathroom tiles for contract signed in June 2014. I have it for 40 rupees for floor tiles and 30 rupees for bathroom including transport. When I checked in shop there are no branded floor tiles available less than 52 rupees. = you have to buy imported tiles of size 1x 1,5 for walls and 2x2 Kajaria K series for floors
30100
Cost calculation for Wardrobe Cabinets
Last answer on 7/4/2020 2:32:12 AM. by Deepan Rajan. Forum started by sujaivilson
2061
Small Bathroom Ideas or Tips
Last answer on 1/27/2022 7:01:08 AM. by S L Gupta (Civil Engg). Forum started by rammohan.g
2536
2708
2793
brick calculation
2122
5207
3542
Contruction Tool
191901
3186
2383
I need 16*40 home sketch with vastu please help me
Last answer on 4/25/2013 10:39:22 AM. by Amit Hasija. Forum started by Sharath
2338
1931
need help/advice to construct residentail house on 100 sq yd plot in hyderabad
Last answer on 2/21/2017 12:44:08 PM. by S L Gupta (Civil Engg). Forum started by Kamal
1793
need some help in vastu for my busines plat
Last answer on 7/6/2015 12:08:26 PM. by S L Gupta (Civil Engg). Forum started by parddep
18435
7411
750 Sqft Construction
3134
false ceiling
1446
Just to be aware and get myself busy,I want to expert on this pop ceiling I need
Last answer on 12/12/2016 11:54:11 AM. by S L Gupta (Civil Engg). Forum started by YARO CONCEPT
1440
Last answer on 12/12/2016 11:52:31 AM. by S L Gupta (Civil Engg). Forum started by YARO CONCEPT
3310
2312
Why
Proper
Through
