Home -> Forums -> Construction -> Raw Material -> Need suggestion on building a strong house.
Fri Apr 18, 2014Total posts : 1
gharsami
gharsami
Topic: Need suggestion on building a strong house.
Hello Experts,
Need you opinion about building below specification independent house.
Site : 15x40
Floors  : ground + 2 + terrace
I got following quotation from one local contractor:
1. Solid block cement size 6x9x15.
2. Steel mat pillar bed 12mm and 10 mm.
3. Roof steel 12mm and 10mm.
4. Beam steel 12mm /10mm and single rod of 16mm.
5. 8mm ring for the colum.
6. Filter sand for plastering.
7. River sand for moulding.
8. 8 Colums will be used.
9. 4.5 inches congret  slab super Birla cement with electrical ISI mark wairing.
10.For all walls 6/9inch.
11. 6ft Foundation.
So all i wanted to know above configuration is good to build a strong and durable house.
I have a tight budget so want to make a cost effective house for now and in next 2 years plans to make it better so for now i can compromise on luxary items but not quality and want to ensure atleast basic structure is good.
And will not face crack / leakage issue etc .... atleast for next 50-60 years ;)
I can ask my contractor if you need more information.
Appreciate assistance in advance.
Tue Apr 22, 2014Post  #1
Dear Sir
       You have collected the quotation from contractor and construct your house with plan and design. If you have any doubt on your contractor work than supervise the work personally.For any specific consultation for any item than write and get answer from the website.
2615
house layout on 40*40 east facing site
Last answer on 9/9/2011 2:11:24 PM. by kawalnain kaur. Forum started by anilpande
3471
hi, i m making house, and i need your suggestion regarding font elevation. and a
Last answer on 4/10/2013 6:28:45 PM. by mike hussey. Forum started by Rashmi
2962
35861
wall paint color combination
1916
Hi, What facing plot is good to build house North east facing plot or East facin
Last answer on 3/5/2016 10:37:39 PM. by JAI PRAKASH. Forum started by Sri
1780
1416
I can share the pictures if anyone can provide me suggestions on the Front porti
Last answer on 9/22/2017 12:00:55 AM. by S L Gupta (Civil Engg). Forum started by SVasan
3118
concrete brick or clay brick
2686
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
3304
GFRC Construction
2691
2082
I WANT TO CONTRUCT DOUBLE STORY HOUSE IN 25X55 EAST FACING PLOT PLEASE GIVE YOU
Last answer on 11/3/2016 12:09:48 PM. by JAI PRAKASH. Forum started by PRAMOD
2090
2223
New Construction
3928
Last answer on 7/3/2020 9:35:44 PM. by S L Gupta (Civil Engg). Forum started by ishan
2873
cost of rcc slab
Last answer on 12/26/2013 11:30:08 AM. by S L Gupta (Civil Engg). Forum started by abdul wahid laskar
2592
Rain Water Harvesting
Last answer on 2/7/2022 9:00:21 AM. Forum started by naveenti@gmmail.co
3501
Paint selection
Last answer on 7/3/2020 10:41:47 PM. by Messi1999. Forum started by anwar
2105
how to correct vasthu defect in house and dentalclinic in a simpleway please giv
Last answer on 8/26/2010 1:40:40 PM. by sabina vanjani. Forum started by shubha
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11102
2189
2037
Estimate
11122
3072
Steel
3039
use of tmt bar
1642
work turned out by labour
2456
estimate
1762
2991
3606
1943
Cost of Steel construction
1612
2135
READY MIX PLASTER
1864
2223
zero slump concrete
Orientation
Orientation of Building
Proper
Why
Environmentally
Environment
Environment Friendly Houses
