Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Need support regarding Beam steel design
Tue Jan 07, 2014Total posts : 1
Sunil Kumar
Sunil Kumar
Topic: Need support regarding Beam steel design
I'm planning for a construction of a building on 2400 Sq Ft plot.
The building will be having 5 floors.
I've got the beam design from my arcitect which says
1. Each beam will be having 8 - 16 mm rod and of 2 ft thickness
2. Distance between 3 columns are 21 ft and 19 ft.
Please let me know if the said steel design is okay to use or need to use more gauge thickness of steel.
Thanks,
Sunil
Tue Jan 07, 2014Post  #1
Dear Sunil kumar
         The design of any structure is based on the calculation made by the structural engineer considering the following factors.
1. Bearing capacity of soil.
2. Distance between columns in both the direction or span of beam and slab keeping in view the plan of the building..
3. Loading i.e.load coming on the different members of RCC i.e. on beam ,column and slab etc.
4. Earth quack safety of the structure.
Keeping in view all the factors by the structural engineer he made structure design of the house or building.
 Now if you have structural design than follow it.
3720
1311
2036
2707
2301
2032
1527
Guide me
1669
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
3837
Roof Beam
4939
COLUMN AND STEEL DESIGN
4939
1896
hi, need all support to make new homes
Last answer on 5/27/2016 6:17:16 PM. by mukesh. Forum started by Dr Tushar Panigrahi
1845
1694
Roof related
Last answer on 3/5/2016 10:32:12 PM. by JAI PRAKASH. Forum started by Pooja
1835
chick door
4126
2327
2162
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by S L Gupta (Civil Engg). Forum started by ijazulhaq
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
Centering
Dining
Dining Room Ceiling
Type
HSD
Precautions
Why
Proper
