Home -> Forums -> Construction -> Layout and House Plans -> New Construction
New Construction
Mon Dec 02, 2013Total posts : 1
ssl3004
ssl3004
Topic: New Construction
Sir
I Have 64L X 34W South facing plots I want 2 construct building 28L X 21W east facing door. I need vaastu advice and floor plan
Mon Dec 02, 2013Post  #1
Dear S S
Layout and House Plans-Construction Questions (40)
3575
construction current rate
1977
Supervision cost
1523
How will the large amount of new construction
Last answer on 9/9/2016 11:16:25 PM. by bhuvaneshwaran bn. Forum started by Satvinder kaur
1181
2668
Estimate require for new construction
Last answer on 7/3/2020 10:05:34 PM. by JAI PRAKASH. Forum started by Pradeep Patil
2208
Need cost for New construction - 900 SFT
Last answer on 3/4/2015 8:32:16 PM. by JAI PRAKASH. Forum started by Marimuthu
i want a good vastu plan for my new construction.south facing.30x40.
Last answer on 10/21/2010 8:47:24 PM. by sabina vanjani. Forum started by ganapathy
2915
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
3163
APP membrane
1823
New construction size 17x34 ft
Last answer on 9/20/2016 10:29:25 AM. by HIRA SINGH. Forum started by HIRA SINGH
2224
New Construction
2656
New Construction
Last answer on 8/6/2020 5:50:51 AM. by S L Gupta (Civil Engg). Forum started by VIPIN KUAMR
1456
new construction on pillar
Last answer on 4/15/2016 1:56:32 PM. by S L Gupta (Civil Engg). Forum started by heyshona86
1488
Start New Construction
Last answer on 3/5/2016 10:16:06 PM. by JAI PRAKASH. Forum started by Salim Bangi
1881
New Construction of 25x56.5 area house
Last answer on 4/12/2015 6:01:24 PM. by JAI PRAKASH. Forum started by Pankaj
2081
new construction
Last answer on 6/25/2015 10:57:48 AM. by seema tyagi. Forum started by ranise02
2272
New construction of house
Last answer on 1/5/2022 12:45:29 AM. by S L Gupta (Civil Engg). Forum started by Atul Bhausaheb Ghule
2635
New Construction in 40 width 70 length west facing plot
Last answer on 2/27/2015 4:07:48 AM. by JAI PRAKASH. Forum started by Ramesh Mayakoti
1804
New Construction
Last answer on 9/10/2014 12:32:22 PM. by seema tyagi. Forum started by KVS Rao
1795
New Construction
Last answer on 9/10/2014 12:28:19 PM. by seema tyagi. Forum started by KVS Rao
2691
2924
2188
2184
2793
4520
1890
2284
2267
2768
3464
2356
1968
2242
3596
2324
2091
2792
1548
2114
Happy
Happy New Year 2009
