Home -> Forums -> Construction -> Cement Concrete Flooring -> New bathroom construction on second floor
Sat May 30, 2015Total posts : 2
Mohd
Mohd
Topic: New bathroom construction on second floor
One person told us that while constructing new bathroom in second floor to avoid wet toilet walls it is better to make RCC /concrete belt (Size of a brick)  at the boarder of the toilet  on the toilet floor bottom level  before affixing tiles and then build concrete block/brick on top of it to make complete wall in addition to water proofing methods.
According to him this action will prevent concrete  hollow blocks/bricks drinking water from bottom of the toilet as we know Indian toilets are always wet at the bottom.
As the bricks drink water from bottom of toilet regularly the wall gets wet
 and is visible from outer wall of the toilet.(Damp/Paint erosion etc)
Please comment on this.
Sat May 30, 2015Post  #1
Good to go with.
Mon Jun 01, 2015Post  #2
Dear Mohmad
         If you construct the wall properly and lay the water supply pipes accurately and test them before laying floor and there should be proper slope to drain water than no such type of problem arise.
Cement Concrete Flooring-Construction Questions (27)
2305
1967
Dear Sir,I need your advice on the new house, which I have recently booked and i
Last answer on 8/8/2014 10:57:40 AM. by Abhishek Vohra. Forum started by Esha
3036
we are constructing a new floor Bathroom size is 4ft 6" x 7 ft what kind of po
Last answer on 8/21/2011 7:28:11 PM. by mvnisha. Forum started by kiran
1970
two bedroom with kitchendininghall with attach bathroom in 600 sqr feet land
Last answer on 7/2/2014 11:22:17 PM. by JAI PRAKASH. Forum started by RAJENDRAN
3270
I have constructed a small house (120 Sq yards) having two bedrooms in south eas
Last answer on 10/12/2012 8:06:32 PM. by krishna. Forum started by Anuj Anand
1377
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
3285
Last answer on 8/11/2017 2:13:58 AM. by HOME. Forum started by Mitesh
2479
Tips for Small Space Bathroom
Last answer on 3/29/2010 3:28:59 PM. by S L Gupta (Civil Engg). Forum started by vankamardi
4027
3560
construction current rate
2495
1958
Supervision cost
917
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
2045
1750
2054
i want to duplex in 35x40=1400 sqfeet corner two side open north and west side p
Last answer on 7/25/2016 5:34:41 PM. by Beenu Phogat. Forum started by murli
1752
Cost reduction
Last answer on 9/22/2014 8:51:26 AM. by Unoara Design Hub. Forum started by sanu kumar
2063
construction of new house on a two side open plot
Last answer on 5/2/2013 1:08:19 PM. by ashish. Forum started by ashish
2622
New Construction in 40 width 70 length west facing plot
Last answer on 2/27/2015 4:07:48 AM. by JAI PRAKASH. Forum started by Ramesh Mayakoti
2299
Roof flooring
1379
3570
Per Sq:ft rate for flooring
1386
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1512
concrete floors
1629
floor construction
2108
Floor thickness
2446
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
Happy
Happy New Year 2009
Bathroom Pictures
Bathroom Lighting
Bathroom Accessories Part-4
Bathroom Decorating Ideas
